Question about Toshiba Office Equipment & Supplies
Error code E-03
Copier misfeed open side cover but there is no any paper and it can not solve problem
  • 163 Answers
SOURCE: Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Posted on Sep 16, 2007
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Posted on Feb 07, 2008
  • 28 Answers
SOURCE: CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Posted on Feb 28, 2008
Kevin Hayes
  • 167 Answers
SOURCE: misfeed and PDF failure
Thewre could be even a small piece of paper stuck. Try looking even closer, and even open a close the access lids to reset the triggered switch. Even a minute pice of paper in the wrong location can cause a sensor to be triggered and until it is reset it will not work.
Posted on Apr 09, 2008
SOURCE: Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Posted on Jul 09, 2008
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
We have the Toshiba studio 350 copier. It says misfeed in copier, but we opened it up and there is no paper in it. It will not work and we can not push any buttons.
Most likely the paper never fed out of the tray. Check each tray and make sure the paper is stacked properly and the side guides are aligned against the paper. What is the error code displayed on the control panel?
Thanks
Apr 13, 2011 | Toshiba e-Studio 350 Copier
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Amber light by the triangle is blinking. Only info I find says it is the memory. Can I solve that?
There can be 5 things that can cause the "attention" light to blink.
Without knowing what the "event log error" is, I'll give you the 5.
1. top cover is open
2. out of paper
3. paper jam
4. paper misfeed
5. fuser missing or not installed correctly
Jan 16, 2011 | HP LaserJet 2550L Printer
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Red blinking light
Hi, this is not a cartridge related problem. As you have written, it is related to the paper misfeed. When removing any future paper misfeeds, always take extra caution as not to destroy the paper sensor. If it jammed near the paper tray area, first open the right cover to see the paper, the try to pull it slowly till it comes out. Never try to force it out as you may tear a small piece which will show you that a misfeed is still on. If it does tear, carefully remove it until its out. If it jams on the fusing unit, release the side levers on the copier or turn the green rotating lever on the front which appears when front cover is open until it ejects it out.
If you are sure there is no jammed paper, make sure the spring on right side of fusing unit, where there is a sensor is retracted to its position. Good luck pal.
Jun 05, 2010 | Sharp AL 1631 Copier
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
May 13, 2009 | Sharp Office Equipment & Supplies
I have Kyocera Mita Copier which is giving error code J20 and shows signs of overheating
Paper misfeed in the Left Cover internal section (J20, J30, J40 to 45, J50,
J52 to 56, J60, J61)
When the paper misfeed has occurred in the Left Cover internal section,
use the procedure below to clear it.NOTE: Supplementary Information
The drum section inside the main unit is sensitive to scratches and
contaminants. When removing paper, be careful not to touch it or scratch
it with your watch, ring, etc.
1 Grasp the Left Cover handles to
lift the cover and open it.
CAUTION: The fixation section inside the main unit of the copier is
extremely hot. Exercise caution in handling it to prevent getting burned.
2 Remove jammed sheets of paper
carefully so as not to tear them.
NOTE: If the paper is torn, be sure to remove all remnants or fragments
from the cassette.
3 If the Duplex Unit (option) is
installed, lift it up and remove the
paper.
from the cassette.
4 Close the left cover.
Jan 28, 2009 | Kyocera Copystar CS-1620 Black and White...
Minolta Di520 false misfeed
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
12 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
