Question about Michael Kors Eyeglasses MK304
HOW SETING A THERMOSTAT? - Michael Kors Eyeglasses MK304
THERMOSTAT SETING
the pointy part facing the radiator....>>>
Sep 19, 2012 | 2001 Chrysler PT Cruiser
Ir 3300 the print out is dark
keep the develop setting between -30 to +30.If the image is too dark then chck the toner you are using as in most case it is the culprit.
Apr 19, 2012 | Office Equipment & Supplies
The oven cannot keep a consistent temperature. It is mostly about 100 degrees above the selected temperature. My landlord replaced the stove about a month ago and the problem is worse now than it was...
It sounds to me like the oven thermostat is faulty, as this is what controls the temperature.
If you can , get a thermometer and place it in the oven and check the temp against the seting with the thermometer, if as you say it is 100 degrees above setting , then you need to replace the thermostat.
Feb 06, 2011 | Hotpoint Ovens
Water is not hot
If your water has NO hot water, then click circuit breaker
Next, click red reset button.
Turn off power.
Open cover on water heater.
If heater has 2 covers, open top cover
After re-seting water heater, insulation must be put back over thermostat to prevent cooler air from affecting thermostat.
1) Reset button is a good starting place to check water heater.
Reset clicks off for a number of reasons, including overheated water.
2) Reset will not reset, then replace thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Resets clicks on, but clicks off again later, you should diagnose the problem.
Clicking reset is not a hazard
Click the reset as often as you want until you have time to diagnose.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
4) Reset is not tripped, and you still do not have hot water:
Then use tester on top two screws (T1 - T3 screws -or- 1 and 3 screws) of upper thermostat to check if you have power.
If you have power, then replace thermostat.
If problems continue, a full diagnosis is needed as per the link above
If you need more help, add a comment and I will respond
Oct 29, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
H/p is freezing up. and acoil is freezing up.w
Two things cause freezing of the coil, lack of charge or lack of airflow, filters, coil and blower assembly all need to be clean, the thermostat will not cause feezing as it is strictly an on off control for convienience
Jul 19, 2009 | Whirlwind FH-778 Air Conditioner
Nokia 5800 phone switching off automatically when it is locked
maybe your mobile seting make like that , so check your seting again if not u can make default seting again like company resetings so probleam is off
Jul 13, 2009 | Nokia 5800 XpressMusic Smartphone
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Manual
get in front of one of the thermostats and call Honeywell at 800-341-0110. If you are prompted, tell them you are an installer and seting up the thermostat for the homeowner.
Good Luck.
Oct 23, 2007 | Honeywell Programmable Thermostat Heater
Michael Kors Eyeglasses MK304 Logo
374 people viewed this question
Top Michael Kors Clothing Experts
Erin Wood
Erin Wood
ray gallant
Da Doc
Are you a Michael Kors Clothing Expert? Answer questions, earn points and help others
