Question about Dishwashers
Defy DDW144 water leak - Dishwashers
2 Suggested Answers
  • 17322 Answers
SOURCE: Defy Dishmaid model DDW144. Detergent dispenser continually caked up. Tried cleaning, drying, re washing. Problem continues.
Run it empty and if the problem persists then it is a plugged spray bar. If the problem goes away, try loading it so that the water is not hitting some item in front of the soap holder
Posted on Mar 11, 2013
How do I fix a water leak on the waterpump of my defy 1300 laundromaid?
Unless the leak is from the gasket the water pump will have to be replaced!
Dec 30, 2014 | Cars & Trucks
My defy laundromaid 1300 is leaking water
What is your question? Where is it leaking water from. Is the water level normal or is it too high. Post some more information and provide model number and seriaql number also.
Sep 08, 2014 | Washing Machines
Why would my Defy 600 Automaid drum stop spinning?
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
See manual for your unit at this site.
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
Pre
Sep 05, 2014 | Washing Machines
Mar 11, 2013 | Dishwashers
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
No water enters the inside of the dishwasher and the motor makes a sound as if under strain. It was working perfectly and then sudenly started leaking from underneath. Could not locate the leak yet. Old...
it is leaking from the seal above the motor in the centre bottom of your machine also check the door seal they tend to leak on older machines as well
Dec 14, 2009 | Dishwashers
Dishwashers Logo
15 people viewed this question
Top Dishwashers Experts
