Question about Multiquip GA6HA Recoil Start 6000 Watt Honda GX340 Portable Generator
Multiquip generator wont start - Multiquip GA6HA Recoil Start 6000 Watt Honda GX340 Portable Generator
My Multiquip GA6HA generator only puts out 1 volt any ideas for troubleshooting?
Sounds like the alternator has failed, possibly a short or open in the windings. Similar to problem I had with my 10 KW unit. I replaced the alternator.
Jul 05, 2014 | Multiquip GA6HA Recoil Start 6000 Watt...
NEED A KEY FOR A MQ8800E GENNY
If you didn't make backup keys, either call a locksmith or unscrew and replace the entire key switch. If you go with latter solution, keep the original key in a safe place, make backup keys, then use the copied keys as primary in your key ring while the original keys are emergency backup. If you loose your key ring, create more keys with emergency backup (original) key. NEVER use the "original" key as primary, or otherwise the copies made from copied key won't fit right.
Nov 07, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
Kubota track ajustment goes slack
Check that the track is on all the rollers properly. If it is a grease adjuster verify that the type of grease is correct. Also check that adjuster is not leaking all the grease back out it may need to be resealed or replaced.
Nov 06, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
When i pump grease into the ajuster to ajust the tracks it goes slack again
The seals in the track adjuster are shot. This happens when the tracks stretch too much and make the adjuster go past its limit. If it is a rubber track it likely needs replacing. Steel tracks you can usually remove a link, replace the adjuster seals and you should be good to go.
My kubota motor cord wont turn over when I pull the cord, it is stuck
you need to undo the pull cord spring and check if the spring on the recoil is broken. replace
Sep 30, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
Kobuto bx25 won't turn off
Have you checked the ground connection to the key switch? I would make sure that you have a clean connection on the backside of the switch.
Aug 07, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
Can we get a maintenance manual for this generator ?
I would go to the manufacturers website and check your model number. I am a plumber and do this frequently for different pumps and other things. Most of the time you can download and print the manual. Just look for literature or manuals.
Nov 25, 2011 | Multiquip GA6HA Recoil Start 6000 Watt...
Honda gx 140 will start but dies right away wont keep running
check the oil level and top it up its most liky low and low oil shutdown is kicking in
if it still wont run try checking main jet , then try cleaning out carb and replacing plug
then check for tight in / ex valve s
cheers
Sep 07, 2010 | Multiquip GA25H 25kW 120V Honda GX160
Multiquip GA6HA Recoil Start 6000 Watt Honda GX340 Portable Generator Logo
Top Multiquip Electrical Supplies Experts
Steve
Gene Haynes
Are you a Multiquip Electrical Supply Expert? Answer questions, earn points and help others
