Question about Broan-NuTone Heating & Cooling
My brivis heating/cooling system is not heating one part of the house. How can this be fixed?
My brivis heating/cooling system is not heating one part of the house. Five outlets are fine, but four outlets do not do anything.
4 Suggested Answers
SOURCE: brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
  • 1456 Answers
SOURCE: heater will work but cooling
Hello
It may just be the extreme heat and humidity causing the perception that the air is not cool. If it is the first extremely hot or humid day in the cooling season, it may take longer than usual for the air provided by your air conditioner to cool off your room or home. Give it longer than usual to get the air cooled. If your unit is baking in the hot sun, this can also cause it to take a longer period of time to get the air cooled. Give the unit at least 20 minutes and come back and check again.
Check the thermostat on your unit and make sure it is lower than the actual temperature in your house. To test this, put your thermostat about 10 degrees lower than the house temperature and see if the condenser kicks on and starts cooling off the air. For a programmable thermostat, make sure the batteries are not dead.
Clean your air filter. If the filter is clogging the air flow due to build up, then your unit is overworking. This will cause the air not to be as cool as the unit is capable of providing. Providing your air conditioning unit with a clean air filter will let it work to its capacity and you will get cool air.
Open the unit and check to see if ice has formed inside. Cool air will not be provided if your unit has frozen up. This happens when the unit is on for long periods of time during extreme hot and humid weather. Turn the unit off and leave it uncovered to defrost. You can help the defrosting process by using a hair blower, set on "Low," to melt the ice. Once the unit is defrosted, put the cover back on and try it again. The air should be cool. Guard against this happening again by turning the unit off periodically for an hour or so. The best time to turn the unit off is while you are sleeping during the night. The cool air will stay in the house until morning and you will not be overworking your air conditioning unit.
Posted on Nov 22, 2010
Can we turn the heat off 2-3 rooms with this brivis wombat 92 gas heating system - heating just the parts of the house we choose.
You could freeze water pipes if bathrooms are connected to those rooms - on a cold winter day (depending where you are). All gas appliances should have a shutoff valve. Shutting that off may screw up the main controller - it won't get the proper signal that the flame started ok.
Aug 24, 2014 | Heating & Cooling
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
May 12, 2009 | Heating & Cooling
Cannot start the Brivis heating device
I have been without heating for the past month since the fan motor in my ducted gas brivis heater filled the house with smoke.
The guy replaced the fan motor, and then it had the same symptoms as yours.
After a month of various tradesman trying to work it out, it has come down to the "thermal switch" within the unit.
Jul 29, 2008 | Heating & Cooling
Brivis Ducted Heating system. No display on Programmable controller inside hoiuse. Electronic Control (Model 14100) located on Heater (outside house)displays "Searching". Have turned off...
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Cheers
James
Jun 10, 2008 | Heating & Cooling
Heating & Cooling Logo
14 people viewed this question
Top Broan-NuTone Heating & Cooling Experts
Colin Stickland
Colin Stickland
brasseng
Level 1 Expert
Paul Carew
Are you a Broan-NuTone Heating and Cooling Expert? Answer questions, earn points and help others
