Question about Garden
Where can i find pump rebuild kit for simpson pressure washer? i need o rings and seals
  • 10,515 Answers
There are so many sites like ebay etc..
The best one is :-
http://www.pressurewashersupplies.com/
Check and let me know, if doesn't find the kit.
Thanks for using "Fixya".
Posted on Jun 23, 2009
Where can i find info of a simpson ws2535 pressure washer pump?
have you tried the dealer where you got it .usually the first place to check for parts
Feb 09, 2016 | Simpson Garden
I replaced water seals and now i have an oil leak. however i have good pressure
I don,t nothing by the brand of this pressure washe but i think there is also a large round oil seal is maybe broken or is not good or ring is not in his seat. but a cuff-kit has most times has not the 3 oil seals on the pump cover under the brass pumphouse this are the first rings simmer rings but before you have no problems with oil leak , are they not forget ? look carefully on the image of the cuff-kit or on the site of the brands models spares . if the brass pumphouse was released then you have replace the 3 simmer rings oil seals yet.
Oct 03, 2015 | Annovi Reverberi AR SJV2.5G27D-F7 Pressure...
Ball valve spring pressure washer detergent line
Not sure what type pump you have but you can buy a chem. injector rebuild kit at Pressure washer parts catalog quick links Pressure Washers High Pressure...
If you need to replace the spring then replace the entire kit. Ball, spring and oring. Most pumps that come on the newer TRoy bilts are AR RMW pumps. the parts diagram can be found here at http://www.arnorthamerica.com/manuals/rmw-om%201006.pdf
The parts for a AR chem. injector are
480480 O-Ring
1250280 Ball
1560520 Spring
Good luck
Jul 22, 2014 | Troy-Bilt 020528 Gas Pressure Washer
Where can I find an oring kit for this valve?
you can get a hole o-ring set at harbor frieght tool on line o-ring kit $10.99
Jun 06, 2014 | Ar 2858 - Pump Unloader Rebuild Kit-SJV,...
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Dont get correct pressure. What type of oil do i
A loss of pressure on this type of washer is normally caused by failing water seals and check valves in the pump. You will need to replace both of these using a pump rebuild kit that will be available by contacting the manufacturer of your machine. The pump oil used will be 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Feb 28, 2011 | Black & Decker 1700 PSI Electric Pressure...
Won't build pressure
It sounds to me that you may have a broken piston ring. That would cause instanainious pressure loss. If not that it is a damaged seal between the high and low sides of the pressurized water. Good luck!
Mar 21, 2010 | Annovi Reverberi Garden
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal kit? Faip 193490.
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
Dec 17, 2009 | FAIP Garden
Pump want start no pressure on spray
you need a bladder and seal rebuild kit , buy from your local small engine guy and you can do yourself or have him do it
Aug 26, 2009 | Karcher 2500 PSI Pressure Washer
Troy Bilt pressure washer model 020209 has very low spraying pressure. How do I repair the pump?
you are going to need a pump seal kit or they may call it a rebuild kit but this sort of thing happens often and you should not have any trouble getting the parts you need with the kit should come a exploded view diagram but request one just to make sure be careful when putting it back together if gyou damage any of the brass or neoprene parts you will be putting it together for nothing lay out your parts on a clean towel keep all dirt and grime away and clean your pump housing really good before you put the new parts in and i mean clean enough to eat off of if you do all of these things your rebuild will probably last longer the the original good luck and get back with me if you need help with the rebuild
Jun 29, 2009 | Garden
Garden Logo
498 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
