Question about Weather King 10AJA3601AH Air Conditioner
Don't blow enough air - Weather King 10AJA3601AH Air Conditioner
  • 1 more comment
  • alex6es Jul 01, 2009
    the air coming from the inside vents does not seem enough.
  • alex6es Jul 07, 2009
    check filter size !?
  • FunnyPlumber
    FunnyPlumber May 11, 2010
    Does that mean the outside fan isn't blowing enogh air or the air coming from the inside vents does not seem enough?
  • 43 Answers
Here are a few things that would cause low amount of air to come out of the registers in home:
1. Something is blocking return air, like couch in from of return air register.
2. Dirty air filter. Clean or Replace!
3. Icing. Check large pipe on outside unit. If it has ice on it shut off sustem and call a qualified technician.
4. Fan speed may be wrong on blower. Put on HIGH.
5. Duct work may be apart. Check duct work and correct if needed. Note: If you have asbestos duct work do not repair. Call a qualified repair company.
I hope I have helped.
Terry
Posted on Jul 07, 2009
1999 F250 Super Duty with a V10 only blows warm air. 30k miles on engine. Coolant level fine, no leaks. Air Blend Actuator moves. Temp in to heater core is 115F, out is 105F
That's not hot enough at the heater core. Engine coolant temp is controlled by your thermostat. It is probably weak or stuck. Replace it. don-ohio (:^)
Dec 30, 2016 | Ford F-250 Cars & Trucks
Maytag dryer model 6000AYW overheats
Probably due to a bad blower wheel. The wheels on these are made of plastic. Over time the wobble out and don't blow enough air.
Home movie of repair:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 15, 2012 | Maytag MDE6000 Dryer
Ignitor glows but short cycles
Ignitors don't "blow flames". But a defective ignitor can glow but not draw enough current to allow the gas valve to open to the burners.
Replace the ignitor. It's the "weakest link" and most likely part to wear out through use in the ignition system.
Sep 19, 2012 | Amana NGD5200TQ Dryer
95 Lincoln Town car A/C is blowing only hot air.
You can try stop leak, but don't expect great results. If the leak is big enough to lose more than 8 oz in a few days, you have a major leak.
And using more than one can of stop leak can cause problems in the system.
Jul 27, 2012 | 1995 Lincoln Town Car
A/c vents not working right
I would make sure you don't have the air blowing out on the floor setting and recirculating. Some vehicles pull air in from floor setting when you set them on recirculate and this causes obvious issues. Might also check your "cabin" air filter, this is different from the engine air filter. Most general repair manuals will tell u where it's located and your local car parts store might also be able to help you find your vehicle's filter location. Your blower fan might also be getting worn out but I would save that for your last check. If the air just isn't cold enough all the time u probably just need to recharge your freon. Hope this helps.
Feb 03, 2012 | 2003 Honda Accord
When I check the oil sight glass for the level, I notice that the oil color tunr into mikly white, so I decided to change the oil, upon draining the oil from the comppressor I noticed that the oil was...
Apparently you don't use the unit long enough to get it good and hot. Then condensate builds up and falls into the oil. ( It's like turning your car ac on high defrost during a summer morning. Where the cold air blows on the windshield condensate forms on the outside). Same principal. It gets just warm enough to cause condensate to form on the inside of the compressor. To correct run longer or you can purchase a heater to go in the oil sump or keep the oil changed. Don't wait until it turns milky.
Aug 31, 2011 | Ingersoll Rand (IRTC2545E10VFP) 2545E10VFP...
Using excess of fuel, sputters when accelerator is released and blows black smoke when accelerating. I would assume it is running rich, I don't know why.
Usually not getting enough air. Try replacing the air cleaner. Choke may be stuck close or partially closed.
Aug 05, 2011 | 1989 Dodge Dynasty
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Air conditioner isn't blowing any air through the vents. Compressor runs outside but blower isn't blowing air through room vents
Hello, kindly check your air blower if is running if not u need to call a service technician to check it, if it is running and blow some air, i guess you don't have enough freon to your condenser, (freon is a liquid like a liquid nitrogen that running thru the aircon to create a cold air.Thanks
Apr 25, 2011 | Heating & Cooling
Weather King 10AJA3601AH Air Conditioner Logo
152 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
