Question about Garden
What carburator kit does a murray 13.5 model # 405000x8e use
Murray lawn mower model number m20300 trying to locate carberator
Murray M20300 is produce by Husqvarna (HOP) group. Its product number should be 96114002702. It uses a Briggs and Stratton engine model number 9T602-5019-B1.
The carburetor PN is 795475 which include the 795083 diaphragm and gasket. This diaphragm and gasket is most problem found when the carburetor fails to operate. Considering the cost of the carburetor kit it is just cost effective to purchase the whole carburetor replacement kit.
You can purchase from online vendors that sells Briggs and Stratton parts or purchase local from a local shop that deals with Briggs and Stratton engines.
Mar 26, 2015 | Murray Garden
18hp ohv cuts out after it gets warm or hot like it is running out of gas
I have a 12.5 hp Briggs & Stratton on a Murray that did that. The carburator is right above the muffler and when I replaced the muffler, I didn't put the heat shield between the muffler and carburator back on. The added heat from the muffler was vaporizing the gas in the carburator where the engine would no longer run once it got hot. Replacing my heat shield and putting a longer pipe on the muffler to get it away from the carburator solved my problem.
Aug 05, 2013 | Craftsman Garden
Trouble starting murray riding mower model # 42560x92a
it has to be ignition coil or gas feed ckeck coil by removeing spark plug leave coil wire connected turn mower over see if you have spark if so it is in fuel delivery if not check and be sure ground is releasing on the flywheel brake if it is then check fuel filter if ok rebuild and clean carburator.
Jul 31, 2012 | Murray Garden
Carburator leak?
Get the repair kit for the make/model and overhaul the carburator while replacing the kit including the gaskets which must solve your leak.
Jul 06, 2011 | Mazda 323 Cars & Trucks
Carburators are not getting fuel
have a murray 20 hp tecumseh has gas in the bowl but wont start unless u spray the carb then it dies when u stop spraying any ideas
Apr 14, 2011 | Tecumseh Enduro VTwin Vertical Engine with...
Murray 21 inch 3.75 lawnmower. Not starting.
buy a ethanol based spray called start ya bastard. spray in the carburator and then pull the cord. 9 out of ten it will start
Mar 14, 2010 | Garden
I need parts for chipper vac
parts are NLA Murray has gone bankrupt, assumed by Briggs & Stratton. Many Murray parts are NLA
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
