Remove Front of Whirlpool Thin Twin Washer - Washing Machines
  • 10 Answers
SOURCE: Whirlpool Thin Twin
Before you run in there with a hammer, is there any way to simply turn off the buzzer alert? I have a different dryer, but I can disable the buzzer. Please check the operator's manual first. If you've gotten to the point of no return, you can disable the buzzer - carefully. Never leave any exposed wires dangling about.
Posted on Mar 16, 2008
  • 15 Answers
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
SOURCE: whirlpool thin twin washer dryer
How do i stop the loud pounding noise on the spin ,ajust the balance???or what else,i think the women that first used it put 2 heavy rugs and threw it out of balance?
Posted on Oct 25, 2009
I need to know how to remove brass claps to top of whirlpool thin twin washer to get to switch pls
do not remove them just push a thin putty knife in and release the top from them then tilt the top back .to access the switch
Mar 09, 2015 | Whirlpool Washing Machines
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Have thin twin stacking whirlpool and need to know how to take off the washer cover.
on this model you should be able to use a flat tip screw driver and push in the locking tabs they are abour an inch in on either side of the machine this should allow you to lift the lid then remove the cross brackets to get the front panel off
Dec 01, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin YLTE6234DQ2 washer is leaking water from the bottom. I need to remove the front panel to see what the problem is but can't seem to get it off. I have looked at suggestions to push in...
have you looked near the bottom of the front panel near the floor,there are 2 or 3 screws located at a 45 degree upward angle(to hide them from view) so they dont show,remove these and the front should hinge upward like an auto hood and the clips near the top should let go when its raised far enough upward
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Twin Thin - Water Leak
It sounds like you have a bad pump. If the bottom of the washer is not solid just lean it back and take the pump off. There should be a streak of water stains on the inside of the pump if it is bad.
Nov 17, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
