Question about Motion Computing M1400 Tablet PC
M1400 pen driver - Motion Computing M1400 Tablet PC
The usb port on my camelio is pushed into tablet.
The USB port has broken off its mounts. You will need that repaired.
Apr 15, 2014 | Motion Computing M1400 Tablet PC
Hisense 7Tablet has stop working.
If its new, return it! if not, the charger may be bad.
Feb 13, 2014 | Motion Computing M1400 Tablet PC
Motion m1400 tablet pc reset bios
My m1400 Can't find operating system and I can't install another xp. It wont boot from my usb cd rom drive, What are my options?
Apr 14, 2011 | Motion Computing M1400 Tablet PC
How can I install win 7 on m1400
You can but I do not recommend it without upgrading your RAM to 1 gb. But you should be able to move the Win7 install files over to a flash drive and boot to it if you do not have a cd drive.
Mar 14, 2011 | Motion Computing M1400 CENTRINO 1.1G 512...
Touchscreen has stopped working on the tablet I
its a software problem try reinstalling the software
Mar 31, 2010 | Motion Computing M1400 Tablet PC
Need to install new os for motion computing m1400 can anyone help
I suggest Windows XP Pro...
You can open a lot more programs than what you can on Windows Vista with the same amount of RAM etc....
Or you could go for Vista.
Is there a CD Drive does it connect to PC?
I have no idea how to work these.
If it connect's through USB Insert a Windows XP disk into your Drive reboot your PC and install it to remove able Drive.
If you want to ensure that it does not scrub your PC copy then disconnect your PC's Hard Drive.
Sorry if I make no sense I am tired.
Hope it help's.
-Tom.
Jul 14, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
Pen doesn't work
have u tried re-installing the driver... if thats the case even if u tried different pens it wouldnt work... plus even if ur driver was fine a different pen wouldnt work for that driver... after re-installation if the pen still doesnt work then theres a 50% chance ur pens not working... One more thing does ur monitor support it???
Aug 30, 2008 | Eaton 30311 Tablet PC
Tabletpc
you cant free download operating system from the web
May 06, 2008 | Motion Computing M1400 CENTRINO 1.1G 512...
Problem with the pen
I don't recall if that uses a "special" pen or not. You can try re-installing the pen driver.
Here's a link to the driver support site:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Just choose "notebook pc" under "select product"
Then "T Series" under "select series"
Then "T4010D" under "select model"
You want the "pen driver / service" driver.
Good luck.
Jan 10, 2008 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Pen Problem
First try updating to SP2 and then get the latest Windows Updates from Microsoft.com.
If that doesn't fix it, here are some Win2000 drivers for your laptop.
http://www.fujitsupc.com/www/content/exe/PenW2k1.4.exe
http://www.fujitsupc.com/downloads/mobile/st3400_pen_w2k.exe
If that doesn't fix it, try these Wacom drivers.
ftp://198.145.255.42/drivers/IBMPC/consumer/503/PenTablet_503-3.exe
Oct 17, 2007 | Fujitsu Stylistic LT C-500 Tablet PC
Motion Computing M1400 Tablet PC Logo
Top Motion Computing Tablets & eReaders Experts
jason
k24674
Chris Larocque
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
