Question about Singer 3116 Simple
Stitch length for zig zag satin binding 8mm equals what number?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 20 Answers
Neat zigzag stitches are usually achieved at "2.5" or below.
Closed up zigzag stitches (close together) are referred to as a
satin stitch its likely you will want to set for 1.5 or at most 2. http://www.searspartsdirect.com/partsdirect/user-manuals/3116-singer-parts-SEWING+MACHINE-manual Look for page 40 in the owners book or scroll down and if you see numbers not on the page but on the scroll bar look for 47. It has some great pitures that can help you out.
Posted on May 13, 2014
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
  • 3 Answers
SOURCE: need to know how to the zig zag stitch on the 132
By turning the bottom dial on the righthand side of the machine, you can change type of stitch. For zig zag, you need to set it to B (seen on the front of the machine). You can adjust the width of the zig zag using the same dial.
Posted on Jun 21, 2009
  • 2976 Answers
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Posted on Aug 28, 2009
  • 5 Answers
SOURCE: Buttonhole making instructions from the manual of
Some machines will start out by sewing a straight stitch all the way around the buttonhole area first and then will zigzag/satin stitch along the sides. Bar tacks will be the last stitches sewn - hope this helps!
Posted on Nov 12, 2009
  • 980 Answers
SOURCE: Singer Fashion Mate 257 won't make a zig-zag
You may need to retime the machine, email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Nov 14, 2009
How do I do a basic satin stitch ? My machine only has patterned satin stitches
A satin stitch is a combination of a wide zig-zag and a short stitch length. Set the stitch width to the maximum. Then while stitching, shorten the stitch length until the threads lay next to each other so no fabric shows between the threads but the threads do not overlap. It would help if you have a satin stitch foot so there is space under the presser foot for the extra threads.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Satin Stitch or Zig Zag Machine Applique stitch
Machine Appliqu Basics 1 Turning right angle corners with satin stitch
Mar 23, 2018 | Sewing Machines
Need to do a satin stitch on Bernini 1630
Just set it for a short stitch length and a wide zig-zag. Test it and keep adjusting the stitch length so the thread will not overlap from stitch to stitch but also that the stitches are close enough so no fabric shows between the stitches.
How to Sew Satin Stitch
Nov 28, 2017 | Sewing Machines
What is the setting for satin stiches
Depends on your machine and the thread you are using. A satin stitch is a zig-zag with the stitch length set so the fabric is not visible between the stitches but the stitches do not overlap.
Satin stitch Wikipedia
Jun 26, 2017 | Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Feb 19, 2017 | Sewing Machines
How do I satin stitch h on a Bernina 1130s limited edition?
Satin stitch is a very wide zig-zag stitch with a very short stitch length. I do mine by dropping the feed dogs and guiding the material through by hand (a lot like darning).
Jan 30, 2015 | Bernina Sewing Machines
Singer sewing machine
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
I need to satin stitch around the edge of a project
Try using the zig-zag setting, but adjust the stitch length to .3 or .4 (very small).
good luck!
Dec 08, 2008 | Baby Lock Esante
When appliqueing in stitch 11 the thread kees looping...
I believe stitch 11 is a zig zag so you are probably decreasing the length to get a satin stitch. You will get a better satin stitch if you select it directly. I think that it is about 29. The machine forms the satin stitch differently than the zig zag and it should look better. If you still get loops on top, you may need to have a qualified technician check the needle to hook clearance. If this distance is too great, the machine skips stitches and you will form loops. Several other adjustments may be needed to get a perfect stitch and a qualified Husqvarna technician should be able to take care of this problem for you.
Nov 23, 2008 | Husqvarna Viking 1
Singer 3116 Simple Logo
67 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
