Question about Coleman Mach 15 Air Conditioner
Coleman 8000 fan works not cooling or heating
  • 4 Answers
Sounds like the compressor is not running. the controller (thermostat) may be at fault, or there may be a wiring problem, either in the lower unit or probably in the upper section.
Posted on May 13, 2014
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: coleman rv rooftop unit, fan runs in on but in auto nothing works
R = HOT 12V
W= WHT- GND
Y = YELLOW / POSSIBLE THERMOSTAT
G= GRND FOR THERMOSTAT
f = FAN
F=FAN
aSSUMING THIS IS A TWLVE VOLT SYTEM- The two f's Would be fan control intake and exhaust - fan direction
White is always ground and so is green.. green is more of a static ground where white is a load grnd.
Red is always hot. in low voltage
I hope this helped. No instructions in kit?
Posted on May 18, 2009
Fan will not shut of, air conditioner works fine have to shut down with breaker why ? coleman mach rv rooftop
Either your fan is in the on position or you have a stuck relay or possible short in the wire.
Jul 19, 2017 | Coleman Heating & Cooling
RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Jun 10, 2010 | Coleman Mach 15 Air Conditioner
Coleman model 5645 inside fan motor not working .. how do you open the cover to get to the fan and motor
pull straight up on the cover. Remove the 4 screws that hold the fan to the heat sink. You can then remove the 2 torx screws and remove the heat sink if you need to. Clip the wires as close to the bad fan as possible so you will have enough for the new fan.
Feb 01, 2010 | Coleman Electric Cooler 40 Beverage Cooler
The 5640 Coleman cooler motor runs, but unit does not cool.
This is a thermoelectric (TE) cooler. There is no gas' to replace in it's cooling system. It is possible the thermoelectric coupler has gone bad. Unfortunately Coleman does not seem to offer a replacement part. If you Google thermoelectric couplers, maybe you can find something on the web. Good Luck.
May 25, 2009 | Coleman (100076) Compact Refrigerator
Coleman rv rooftop unit, fan runs in on but in auto nothing works
R = HOT 12V
W= WHT- GND
f = FAN
F=FAN
May 18, 2009 | Coleman Mach III Air Conditioner
Coleman mobile home electric furnace
Peace,
It seems you need hands on servicethis time !
ngafm
Bless You,
Please leave me a rating before you sign off!
Thank You
Sep 07, 2008 | Heating & Cooling
Have a coleman 5640 heating/cooling unit and the motor won't run unless just a tiny amount of pressure added?? Any suggestions?
Yes, to change from heat to cool is done by reversing the power plug that is close to the housing. Matching the blue on the plug(as I recall) makes it cool. The red to blue makes it a heater. If it is currently heating, the unit works fine, it just needs the polarity reversed.
Good luck,
Glenn
May 04, 2008 | Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
102 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
