Question about Oreck Vacuums
Oreck DTX1400 Handle unit On/Off/Powehead Switch my repairman installed different switch, now I can't turn off at handle. Frustrated, I am not a idiot. What do I need to do?
    Genius:
  • 1,114 Answers
Have the repairman who installed the wrong switch fix the problem.
Posted on May 13, 2014
Testimonial: "I appreciate your response, we own a car/tire repair business, I could have called that one! I wrote that frustrated, abbreviated question In the wee morning hours of frustration. My Oreck DTX1400 has a On/Off Power Head switch as well as it also works as a Unit On/Off Switch (schematics part 60A) if the pedal on the canister is on. My dealer/repair person used the switch Oreck lists (Part #82267-01) as the replacement part, which is the part that was used but now the unit cannot be turned off at the handle. You must use the pedal on the canister to turn it off. Has the switch been reengineered? Can the unit be repaired to work as it did or am I out of luck?"
  • 19 Answers
SOURCE: How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Posted on Dec 22, 2007
Agent Don
  • 310 Answers
SOURCE: wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Wiring diagram Oreck XL2
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 09, 2008
  • 4 Answers
SOURCE: How do you remove the Handle from the Hoover Windtunnel Deluxe to replace the switch?
Removing the handle assembly should be easy after removal of the two screws. It may be binding or hanging up on the self-propel cable...or the plastic may just be stuck/binding. Note that the handle slides in and out of the vacuum unit along the same axis as the two screws (i.e. slides straight off the back towards you when you are standing behind the vacuum). Try to pry it off gently w/thin-bladed screwdriver or butter knife (careful now!). Not sure about the smoking issue but you may have a severely plugged filter and the unit is overheating as a result. Check that out immediately/first to avoid fire or expensive motor burnout.
Posted on Jan 02, 2009
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
  • 8404 Answers
SOURCE: Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Posted on Oct 02, 2009
How do I access a wiring diagram for handle switch assembly on an Oreck XL upright vacuum?
Go to www.hescoinc.com. Click on schematics under information on the left side of the page, then click on Oreck and find your model. Hopefully that has enough detail for you. You can order parts from them too at prices lower than most other distributors.
Feb 02, 2015 | Oreck XL Ultra Bagged Upright Vacuum
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
Oreck vacuum repair manual
Unless you have a foot switch, the on/off switch for most Oreck vacuums are up in the handle. You will have normally 6 screws that hold the handle halves together. Take the screws out and then split the two halves apart and you will find the switch inside at the top front of the handle. You may have had a wire come off of the switch and it just needs to be plugged back onto the switch and then you can re-assemble the handle and you should be back in service. If you have a foot switch, you might need a meter to check continuity throughout the vacuum because you may have a broken wire somewhere. Hope this helps you solve your problem.
Jul 20, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Reset button
on the ergonomic handle design the vibration will sometimes cause one of the switch leads to come loose. Remove the handle tube. Lay the handle tube flat on a bench or table and remove all the handle screws. Work handle haves apart and you will be able to see if the switch leads are loose. If not, the wires inside the power plug may have become separated by somebody yanking on the cord, rather than pulling the plug. With a meter or test light, you can check continuity between the plug and handle wiring. The only thing left is the motor, but let your local repair guy do this, because it can be a bear to get out and re-installed.
Jan 16, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Have an Oreck XL upright, when switch turned on no "Power" checked receptical and power supply is OK
What typically happends is if the vacuum falls over the cord will come disconnected from the switch.
there are 6 screws on the handle if you unscrew them the handle will seperate down the middle. you will see a few wires in there. the whites wires should be wire nuted together while the black wire from the long cord, the side that you plug in to the wall, would plug on to the top of the switch, unless you have a 2- speed vacuum the it also would plug into the top but on the prong that is closes to you. it will make sense when you open it up. there is another cord that come up from the base of the vacuum to the handle which is called the up cord. the black wire that comes from that plugs in to the bottom of the switch.
if that doesnt work then you might have a short in your cord that will need to be replaced or your motor could have gone bad. and oreck motor typically last about 8 to 10 years.
if more problems occur i would recommend bringing it to and authorized Oreck dealer. If your vacuum is under warranty it will be fixed for free.
Sep 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
How do you install the switch for the oreck vacumn properly?
The Orecks I have worked on have a plastic handgrip area surrounding a metal handle rod.
Undo the handle screws and the handle should separate like a **** shell revealing the switch and harness. Pull gently on the wire terminal with a pair of needle nose pliers not behind it.
Be careful not to flex the switch contacts as they may break off. reinstall any insulation around the switch before reasembling.
Sep 08, 2009 | Oreck XL2600 Vacuum
On/off switch for Oreck XL2600HH
Would have to assume by now you figured this out. However, need to open up the handle. It is a clamshell arrangement. Remove switch from handle, pull one wire at a time from the switch. The electrical connectors are a push-on type. Replace each one, one at a time, to the new switch, and then re-insert switch into handle. Close up the clamshell, tightening all of the screws, but do not strip the plastic housing.
Jun 19, 2009 | Oreck XL2600 Vacuum
I need diagram of replacing on/off switch for Oreck XL2600
Manual would not, they want you to pay a service tech.
Believe this model has switch in grip,
1. Unplug unit.
2. remove screws from grip.
separate the grip halves to access switch.
3. I believe the power cord, where it enters the grip, has slip on terminals that fit on the switch. Just substitute the wires and re-assemble.
Should not require any soldering. Be careful, routing of the cord in the handle is difficult as I remember, depending on the year model, sometime in late 90s they went from a molded in strain relief to a serpentine path.
Reassemble of handle on upright
place handle half with the posts that hold the screws facing up.
silver pole with hole that goes completely throuigh goes over lower screw post (Long side)
static wire - L shaped end goes in small hole on opposite side of handle just below
vacuum switch hole, curve of wire should follow curve of handle and fits into top of
silver pole and pushes againt it providing push to hold siver pole.
hope this helps
Apr 02, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
65 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
