Question about Akai CSDV6R Cassette/CD Boombox
Boombox won't play CD; says "OP"
The code "OP" appears on the readout screen on this unit, and it won't play CDs
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Clock readout indicates power, but nothing else working
In most cases it can be traced to the audio output ic as the problem, because part of the B+ is fed back in the radio. There is a remote chance a fuse has blown located near the ic.
Feb 25, 2012 | Memorex CD Boombox, MP3126PUR Boombox
When I put a cd into my boom box the display reads "no disc". can you help? Everything else works great so I'd really like to fix it if I can. Thanks
LASERS ARE LIKE THE OLD RECORD NEEDLES THEY ONLY HAVE A LIMITED LIFE AND GET WEAKER WITH AGE HOW OLD IS THE UNIT ANDARE YOU PLAYING BURNT CDS IF SO BUY BETTER BLANKS AND MAKE SURE WHEN YOU BURN YOU DO A RED BOOK BURN.
Nov 03, 2009 | Sony Xplod CD/Cassette Boombox with AM/FM...
My RCA RCD160 Radio/CD playder will not play CDs.
Try cleaning the lens in the CD player with a cotton swab and alcohol. If that does not resolve the problem, it is likely that the optics are defective and need to be replaced.
Dan
Mar 25, 2009 | RCA RCD160 Radio/CD Boombox
My boombox is displaying the word "Protect" in the display. ???
The protect message indicates that there is a problem with the final stage of the amplifier section. This unit will require repair as a reset will not clear this. There is an audio amp IC inside that needs to be replaced. Figure on about $15 or so for the part.
Dan
Dec 09, 2008 | Sony Boom Box With CD Player & Cassette...
I HAVE THE ORITRON #OP1011
I have boombox op 1011 and can't get play button to work for cd's
Aug 21, 2008 | Oritron OP1181 CD Boombox
Cd's wont play
can you please post here the model and the part # of the cd player.. & please kindly inform me the type of cd she play in the unit, is it a Audio CD..?
Thanks..
Apr 16, 2008 | Audio Players & Recorders
Boombox won't play most CDs
Hi there , heres a simple case of the recording format on the cds , its likely that your daughter's cds are recorded on a computer in a format probably mp3 or higher speed thats not compartible with your boom box . The solution to this is to record your cds in Normal format , and they will surely play !
Mar 26, 2007 | Philips AZ1303 Radio/CD Boombox
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
Akai CSDV6R Cassette/CD Boombox Logo
44 people viewed this question
Top Akai Audio Players & Recorders Experts
Michael Harrier
andrewcahoon
 Grubhead
Grubhead
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
