Question about GE Refrigerators
Ge profile ptc22sfmarbs no power - GE Refrigerators
GE Profile PFS22MISBWW not cooling, power/lights on. LED & Fan off
This is a common problem with the GE Profile. In most cases this is caused by failure of the motherboard. If you would like a manual, part numbers and assistance on how to repair please let me know because the instructions are detailed and a lot to Wright if you are only wanting to know what is wrong. You can find a service manual by going here http://appliance911seabreeze.com/
Jun 03, 2013 | GE PDS22LBN Bottom Freezer French Door...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My GE Profile oven is beeping every minute. I've
    if its an f-7 error code its due to a stuck error code
    Feb 06, 2010 | GE Profile JT955 Electric Double Oven
    Refrigerators Logo
    15 people viewed this question
    Top Refrigerators Experts
    KJ4QOB
    Da Doc
    Jim Akins
