Question about Comcast XFINITY
How to reset comcast signal box
ERR-0x00f
  • 1,087 Answers
Unplugging the power cord to it and plug it back in. That is a soft reset for Comcast boxes.
Posted on Apr 03, 2015
My comcast on demand has been down for over a week, can I fix this myself?
Depends on what the issue is. If you have a cable leak in your home and the noise is getting into your coax "ingress" then yes you can walk around all your cable fittings and tighten them all up. Ingress is white noise or voltage passing into your TV signal coax. This corrupts the data packs your box uses to get to the Cherry picker on demand server and gives you a no access display.
Mar 08, 2014 | Comcast XFINITY
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Sylvania LC427SSX worked fine until comcast upgraded the cable box cable modem. TV works with DVD player but not with the cabe box. Could this be a firmware issue that requires me to upgrade the software?
In my area, Comcast has blocked all free watchable basic channels. You now need a very small but special box to receive those. If it's a conventional cable box, you might have to call them to send a signal to reset it.
Feb 14, 2014 | Sylvania LC420SS8 LCD TV
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
TV Guide on Line for viewing and recording was there and poof
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at richard_gladney@yahoo.com
Good Luck!
Mar 25, 2009 | Panasonic DMR-EH50 DVD Recorder
On screen guide
I am in Atlanta and have aPanasonic DVR that was working fine and sometime during the past monthor so we lost the channel listings. I've tried many resets as well withnegative results.
I called Comcast tonight. The agent helping metook a long time to research the issue and gave me this answer (whichsounds reasonable). By the way, this is for the Atlanta area and maynot be applicable to other areas of the country.
Due to delaysin the conversion to broadcast digital and the fact that Comcast isexperiencing bandwidth issues, they have digitized the "channellisting" signal. By mid-June Comcast's signal will be all digital andyou won't be able to watch a TV connected directly to Comcast cable -regardless of whether it has digital or analog tuner (or both). This iscontrary to what I'd heard before.
After mid-June, you'll eitherneed to use a cable box OR what she called a "Digital TransmitterAdapter" (let's call it a DTA). Prior to being converted to "full"digital, you'll get notification from Comcast. She said I'd be able toget 2 DTAs at no charge (I currently have one Comcast HD DVR box).Additional DTAs would be $1.99 a month. DTAs will only provide accessto the "basic" cable channels, but the good news is that the PanasonicDVR should be able to obtain its channel lineup through this DTA box.
Good Luck!
Mar 21, 2009 | Panasonic DMR-EH50 DVD Recorder
Belkin G wireless Router
Do you have an all-in-one router from Comcast? For example, do you have the cable (RF) line and your PC plugged into the Comcast router? If so, unplug your PC from the Comcast router and connect the Internet port of the Belkin to the ethernet port on the Comcast router. Then plug your PC into the LAN port on your Belkin.
[PC] ---> [Belkin] ---> [Comcast] ---> Internet
Once you have connected your boxes as displayed above, you will need to power everything off and bring up the boxes in the following order:
Comcast (wait 60 seconds)
Belkin (wait 60 seconds)
PC
If you cannot get out to the internet, momentarily press the reset button on the back of the Comcast box. Comcast routers are weird. A poweroff should reset the router but I have seen a few times where nothing works until the reset button is pressed (this is also recommended by Comcast).
I hope this helps.
Dave Grannas
Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
Can't get 1080
VJ-TRY RESETTING THE COMCAST RESOLUTION BY TURNING OFF YOUR CABLE BOX THEN PUHING THE CABLE BOX MENU AND YOU CAN USE THE ARROWS ON CABLE BOX TO ACCESS THE 720P AND CHANGE IT TO 1080I.JOE TV
Nov 23, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Comcast XFINITY Logo
110 people viewed this question
Top Comcast Televison & Video Experts
Mike
Mike
Jay Plesset
Are you a Comcast Televison and Video Expert? Answer questions, earn points and help others
