Question about Sony DCRHC26 MiniDV Digital Handycam Camcorder
MY SONY HIFI 8 CAMCORDER THE DEVICE THAT HOLDS THE TAPE WILL NOT GO DOWN SO THE CAMERA WILL CLOSE
The piece that holds the tape will not go down so the camera will not close
  • 53 Answers
Oky can u switch on off the unit.Do not put the tape when u r doing on and off. open the cassette compartment cover,see is there amny movement of Arms or TG
Posted on May 22, 2014
SOURCE: loading tapes
Hello, exact same problem here, closes fine when no tape inserted, but with a tape, the camera won't close, just keeps ejecting the tape.
Another problem that I encountered is that the camera will not take pictures anymore.
When I press the button, it beeps, but there appears a green dot on the screen,
My handbook tells me, when this dot appears on the screen, this means he camera will not take a picture, it however doesn't tell me how to solve the problem.
Anybody
Posted on Jan 05, 2008
SOURCE: sony ccd-fx310
My camera won't play back.  Occasionally, if I ffwd it will show the picture otherwise its a blank screen.  Any ideas?  I've tried cleaning the heads a few times now
Posted on Feb 02, 2008
welcomejee
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
SOURCE: my camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Posted on Apr 26, 2009
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Posted on May 06, 2009
Tape door will not go down
CAMCORDER TAPE DOOR WON'T CLOSE { C:32:11 } FIX ...
? 13:13
https://www.youtube.com/watch?v=CBqP-Q86UyM
Jul 9, 2014 - Uploaded by GotNoEvidence
Here is a fix that does not involve disassembling your camcorder, sending to the ... This worked for us when the tape door wouldn't close on our old Sony HDR-HC9. .... is you can use the same method to REMOVE a tape when the tray will not lift! ... Yes yourvideo helped me fix my DCR-HC96 camera.
Sony HDR-HC3 Tape Door Won't Close with C:32
Nov 18, 2015 | Sony Video Cameras
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
I can't see any image of my tapes on the Sony DSR-PDX10 DV Digital Camcorder.
Try playing one of the tapes on another Sony DV/DVCAM device and make sure the tape is OK. Also, try running a cleaning tape through the camera for 8-14 seconds (no longer!) on playback. If this does not remedy the problem, then your camera needs repair.
Nov 30, 2010 | Sony DSR-PDX10 DV Digital Camcorder
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony DCRHC26 MiniDV Digital Handycam Camcorder Logo
65 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
