Toshiba e studio 212 copier. Gives error code e03. Paper has been cleared and no particle inside, all sensor in place. Still gives error e03. What to do?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 20 Answers
Search carefully onto the fuser cover for the actuator for exit sensor.
There is a spring that moves the actuator into normal position when the paper has passed. If it seems the spring is out from the actuator it will think there is still a paper jam. The best bet would be to call a service company to come out and make repairs if you are unable to get this spring back into place. After resetting the spring into the correct location, restart the machine and see if the problem continues. If it works and then goes into error mode again, it is likely this spring and or senor will need to be replaced.
Good luck.
Posted on May 13, 2014
2 Suggested Answers
andi_bunkka
  • 102 Answers
SOURCE: My Toshiba E-Studio 650 is displaying a paper jam in the copier. I have removed all paper jam and I have replaced sensor. What am I missing?
There are other sensors to check or verify that there is continuity in the wires of the sensor that you've removed
good luck
Posted on Apr 25, 2012
E03 error code on my toshiba e studio 163 printer. How do I fix this problem?
E03 Paper remaining inside the equipment at power-ON.
Open the cover of the unit/area whose picture is blinking on the control panel. Is there any
paper on the transport path?
Remove the paper.
Nov 14, 2017 | Toshiba Office Equipment & Supplies
E03 code toshiba photocopier
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Mar 15, 2016 | Toshiba e-Studio 207 Copier
E03 error in toshiba e studio 207
Power-ON jam:
1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the MAIN board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are open circuited.
4) Replace the sensor.
5) Replace the MAIN board.
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
What is the reset code of toshiba estudio 181
i have toshiba e studio 181 it gives an error of paper size its not accepting any paper size expect A3 size plzz help how to set paper size
Sep 12, 2012 | Toshiba e-STUDIO181
good luck
Apr 24, 2012 | Toshiba E-STUDIO 650 Copier
My Toshiba E-studio 650 keeps E03 which means paper jam how can I fix this?
Probably moved some sensor caused by the paper jam, the sensor looks out of place or dirty and also check the continuity of the cables.
Apr 24, 2012 | Office Equipment & Supplies
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
261 people viewed this question
k24674
jasbo
jasbo
