Aopen ux915g Can you use pentium D cpu on ux915g motherboard?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 20 Answers
Yes. Any Intel Pentium 4 processor will fit fine. That said A P4 processor is fast, but the Pentium D is much faster. The D stands for Dual Core. This means that they have two on die processor cores instead of just one, as the Pentium 4 does. Two processors also makes it better for "demanding" applications.
The Pentium D is better if you have a motherboard that will utilize the technology. As stated the Pentium D is Duel core. This is Intel's way of creating the closest environment of a true duel processor. The HT is for Hyper-Threading which acts like a zipper and allows several applications to process at the same time. The Pentium D will really make a difference when used with the new 64 bit operating system.
However, HT (Hyper-threading) P4, does have emulated Dual Core processing. In short, the processor makes the computer think its runing a dual core. The Pentium 4 also has a couple different levels, so if you are trying to make a comparison, make sure that you look carefully.
Although neither can match the power of an Athalon or an AMD x2 processor. If you are buying, get something with 64 bit processing. WAY faster and better for games and high graphic systems.
Posted on May 13, 2014
2 Suggested Answers
SOURCE: AOpen MZ915 UX915G-M, motherboard pin out
I have the same motherboard. The solution that worked for me uses the pinout for a similar AOpen cube, the EX65. See
http://www.fixya.com/support/t2707644-anyone_know_pin_layout_front
Posted on Aug 16, 2010
How to build pentium 2
well first you need to get the following ..
  • AOpen HX45 Computer Case
  • Abit BH6 motherboard
  • Pentium II processor
  • 128 Mbyte, 100 Mhz, 8 ns, PC-100, 168-pin SDRAM
  • Focus 2001W Keyboard
  • Logitech M-S34 2-button PS/2 mouse
  • Four 9-inch cable-ties (also known as zip-ties) Garbage bag twisties will do, but won't look as good.
  • ATI Xpert@Play 98 with 8 Mbytes Display Adapter
  • AOpen 7277c 17" SVGA monitor
  • Panasonic 3 1/2" 1.44 MByte floppy drive
  • Maxtor 9136008 11.5 GByte, UDMA, EIDE hard disk drive
  • Toshiba SD-M1102 DVD drive
  • Additional IDE cable
  • AOpen FX-3D Plus ISA PnP Sound Board
  • MLi 699 Speakers
  • AOpen FM56-P PnP PCI V.90/K56Flex 56K MODEM
  • Windows 98 OEM
  • ATI DVD Player CD
Aug 13, 2014 | Computers & Internet
What are the different cpu's that ux915g motherboard will accept? Can it take a pentium D processor?
This would be the Aopen motherboard from the cube...
They take the following CPU's
Processor Number
Processor Frequency
FSB
Ratio
Cache
5 Series
560
3.60GHz
800MHz
18x
1MB L2
550
3.40GHz
800MHz
17x
1MB L2
540
3.20GHz
800MHz
16x
1MB L2
530
3.00GHz
800MHz
15x
1MB L2
520
2.80GHz
800MHz
14x
1MB L2
3 Series
350
3.20GHz
533MHz
24x
256K L2
345
3.06GHz
533MHz
23x
256K L2
340
2.93GHz
533MHz
22x
256K L2
335
2.80GHz
533MHz
21x
256K L2
Note: With CPU changing rapidly, there might be fastest CPU on the market by the you received this installation guide. This table is kindly for your references only.
May 13, 2014 | Computers & Internet
I am wondering if I can put a Intel Pentium 4 Processor 3.20 GHz, 512K Cache, 800 MHz FSB into a AOPEN MX4GE motherboard, the socket type is the same but I am not familiar with the FSB settings to...
I would guess not, but If you already have them both, then try it. If not then I'd get a cpu or motherboard to match the other. I once got a 2.8ghz p4 and wanted to swap it for a 3.2ghz I had lying around, quickest way was to try it out, it didn't work so I swapped them back and put the 3ghz in another pc later on, both still worked perfectly.
Feb 04, 2011 | AOpen MX4GE Motherboard
Jun 22, 2010 | Computers & Internet
I m using A open MX3W pro -v motherboard ... In that pentium 3 processer is not working ... But celeron is working
Try adjusting the CPU Frequency in Bios Setup for your processor. You can also try downloading the lastest BIOS release from http://global.aopen.com/userdownload_List.aspx?RecNo=2931&Model=244
May 13, 2010 | AOpen MX3W Pro-E (91.88210.241)...
Amd 2600+ doesnt work
Check your bios version and make sure it is correct bios. You can check the Aopen site to download the new bios and flash utility to install it. Be carefull and make sure that it is CORRECT bios for EXACT Motherboard. The bios can be flashed wrong and leave you with a paper weight. Good Luck
Nov 22, 2009 | AOpen AK77-8XN Motherboard
Problem with my multimedia controller
This link may be what you need.
http://usa.aopen.com/download.aspx
If not, please consider clarifing your 2 devices are integrated into the motherboard or are added on cards
Sep 25, 2009 | AOpen Computers & Internet
Missing CPU
AX4BS-v intel chipset pentium 4 sd ram
MX4GE socket 478 pentium 4
AX4B intel 845-d
hope this helps
Jul 02, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Processor
Hi Don, the Celeron is a knock off of the Pent4. (Cheeper version CPU). Could be a bios glitch but not worth flashing the bios.
If it ain't broke, don't fix it. That could ruin you're whole week!
Enjoy!
Mike
May 07, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
Cpu size
Hi handydak
For your Mobo
VKM400 AM-S Try this link it will tell you what max size CPU & Memory you can install to improve performance.http://download.aopen.com.tw/Default.aspx
Regards,
ajb2000
Dec 28, 2007 | AOpen vKM400Am-S Motherboard
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
