Question about Frigidaire ATF6000ES Front Load Washer
Front load washer e21 - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
Posted on May 16, 2014
2 Suggested Answers
  • 100 Answers
SOURCE: Affinity Front Load Washer E21 first, now E23
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed or wire off pump. Replace control board or wire.
1. Check the drain hose for restrictions.
Restriction. Correct problem.
No restriction. Go to step (2).
2. Start the washer and check for 120 VAC at the
drain pump.
Zero. Replace the control board.
120 VAC. Remove the pump and check for
blockage. If blocked, remove the restriction,
if not, replace the pump.
Posted on Oct 30, 2007
Frigidaire code e21
I understand that you are receiving an E21 code on your Frigidaire washer, model# ATF6000ES. The E21 code means that water is not pumping out fast enough. Check your drain hose to make sure that it is not kinked or clogged in any way. Also, make sure that your drain pipe is not clogged.
After checking these, you will want to reset you appliance. You will do this by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire ATF6000ES Front Load Washer
E21 code on Bosch Dischwasher...what does it mean
E21 Circulating pump blockage
This would be caused by a blockage or a poor water flow from the main motor of the dishwasher. This can be caused by a capacitor failure or for other reasons.
Dec 08, 2013 | Kenmore HE2 Plus Front Load Washer
Front load washer makes load noise when time to drain and spin
some times there is a panel on the bottom 1/3 of the washer with two or three screws at the very bottom if you remove that panel you will see the pump. the center part of the pump can be removed turn counter clockwise and pull check inside for an object
Nov 22, 2013 | Kenmore 4.0 cu. ft. Steam Front-Load...
E21 error affinity
Hello markramos66 - An error code E21 commonly refers to the water in your washer is not pumping out fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Apr 14, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer e21 error appears after running about 20 mins into the wash cycle,i check the clothes they are still wet,although no water is still left,i go to the spin only cycle to get the...
Hello debbiecantu1 - Typically error code E21 indicates an issue with the water not pumping out fast enough. Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Dec 13, 2012 | Frigidaire ATF6000ES Front Load Washer
My frigidaire washer has e21 error code and wont start
Hello - The error code "E21" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
Eiflw55hmb error code e21
Ok you have a front load washer made by Electrolux. Prbably says Fridgedaire.
E21-water not pumping out fast enough.
There could be a clog in the filter or a kinked hose. Check all the hoses and the filters. Some models have inline filters just before the pump. Filters are designed to protect the pump.
If you need further assistance please feel free to contact.
Jul 19, 2011 | Washing Machines
Have a erro code E21 What is it
The E21 error code means the water in the washer is not pumping out fast enough. The solution is to check the washer installation. Make sure the drain hose is not kinked. Make sure the drain pump has 120 volts in the drain cycle. If it reads zero the control board will need to be replaced. If not, then it's the pump.
Nov 01, 2009 | Electrolux EW1000i Front Load Washer
Error code E21
you need a phillps screwdriver remove the top . control panel then the front... hope it helps
Aug 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Error code E21
E21 Water not pumping out fast enough. .
Check for Restriction in drain pump or hose...
drain pump. if no voltage Replace the control board.
Frigidaire ATF6000ES Front Load Washer Logo
866 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
