Question about YouTube Videos
Key hole.tv - YouTube Videos
    Problem Solver:
  • 8 Answers
I can not get on my youtube account
Posted on Jun 24, 2009
I have 32 inch Sinotec LED TV. When I press any button on the control panel "KEY LOCK " appears . How do I deactivate the key lock without a remote control
default would be to unplug for 12 hours or sometimes there is a little pin hole reset hole type button very small that you have to stick a pin or paperclip end into on the front by the power button, hold it in for 5 sconds sometimes this will reset if not get a new remote a universal one.
Mar 07, 2016 | Televison & Video
How do you reset the tv?
Ashley
No Model or Brand of Projection TV supplied?
Disconnect Power. Look for reset button or pin hole.
Hold a key down on Start Up
Take it's internal battery out?
Mar 03, 2015 | Televison & Video
How to remove a dvd when no power to tv?
If not already done so, check the instruction manual (on-line if you don't have a copy) to see if there is anything about this in the troubleshooting guide - it may have a key combination on the remote or similar to force eject the disk. Failing this, if you can open the outer flap of the disk drawer without forcing it, you may find a small reset hole which can eject the disk manually by using something like a straightened paper clip to put into the hole and press the recessed button that is accessible via the hole. It can be a little difficult to find as depending on the design of the TV, it can be obscured behind the plastic of the TV body. Don't be tempted to force the disk drawer out as this can knacker the mechanism completely. BTW, if the disk is not a pre-recorded disk, (recorded yourself), this can cause an error like this - powering everything off and then pressing and holding the eject button as you power up may result in an eject. Hope it helps!
Feb 24, 2015 | Naxa Ntd-1952 19" Widescreen Hd Led 1080p...
Ignition key will not go into ignition switch
check there is no obstructions in key hole. its not uncommon to put fluff in the key hole from removing key from your pocket over time it will block the key hole.
May 03, 2013 | 1994 Oldsmobile Eighty Eight
HOW CAN I CONNECT MY SATELLITE C660-10T TO MY TV?
Hi. You need a VGA cable, the same that is used for Desktops (from monitor to base unit). Connect it to your laptops VGA port (a square(ish) port with holes in it), the the other end to a similar port on your TV. Switch laptop and TV on, connect your TV to PC input (read your manual if you are unsure), then on your Laptop select Fn and F8 or F5 (look for the Function key with two square boxes - or a small laptop and a larger box). Pressing those keys together will push the image to your TV.
Apr 02, 2013 | Computers & Internet
Lost key to cabinet !!
The locks on sewing machine cabinets are notoriously easy to pick. Is the key hole round or flat? If it is round, use a flashlight and look into the hole. It could be a triangle shaped hole, a square hole, or the male opposite of either. For a hole, find a small screw driver that will fit and fill it between two corners (of the hole) and rotate. For the male opposites, you will need something like maybe a skate key or a clock key, or possibly a piece of hard rubber tubing to fit onto the protrusion. If key hole is flat, find some old keys that slip easily into the slot and wiggle & turn gently until you find one that works.
Apr 04, 2011 | White Sewing 2037 Mechanical Sewing...
Need to take a flat panel tv off the wall mount
Here are a few spots you can try. Underneath, there might be locks that use alan keys. You might need a long alan key depending on how big your TV is. Unscrew these alan keys as much as possible. Some mounts require up to pull the bottom of the TV out and then lift straight up. Try using a flashlight and look all around the TV, Also check the top. Some have clips that need to be pushed to the side. These clips have holes in them and sometime held in with zip ties to keep them locking the TV, You will need to cut the zip ties. Hope this helps...
Mar 15, 2009 | Televison & Video
Digix Manual/diagrams do not match my TV connectors
Simplest way. ++++++++++
If you have red, white and yellow on each match those and use a cable with 3 strands - red, yellow and white ends with RCA jacks. Use the setup key to get an onscreen display to set options.  Make sure they are the video/audio OUT on the DVD not in.
On your TV it's probably Video 1 or something like that - you can usually test this by putting the cables into the front of the TV. The TV remote might have some key like TV/Video to get to the Video input screen.  Make sure you check the video-in ports on the TV - not the video/audio-out.
Option if red is missing +++++++++++++++++ If the DVD player just has yellow and white then just connect yellow and white (it will be mono) on the TV.
It shouldn't matter if the holes are vertical or horizontal.
S-video +++++++ If both TV and DVD have S-video ports then connect those - they will give you better video than the yellow.
You will still need to connect red and white sound cables.
Jan 04, 2009 | Digix Televison & Video
Key won't come out
u got 2 use a small screw driver right under key ther is a hole put srw driver in hole turn key back
Nov 02, 2008 | 1997 GMC Jimmy
Progaming the remote
1. Turn on the device you want to set-up (ie: TV, DVD, etc).
2. On the remote control, press the device key for the device to be set-
up. For example, to set-up a TV, press the TV key; to set-up a DVD,
press the DVD key, etc.
3. Press the "SET" key and hold until the small light ("LED") on the
remote control blinks twice, then release.
4. Enter the Code for your device. If you've done it correctly, the "LED"
light will blink twice. (Note: 'Codes' are listed in the instruction booklet).
5. Press the "POWER" key and the device will turn off. codes follow
Mar 02, 2008 | One For All URC4220 Remote Control
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
