Question about Whirlpool Washing Machines
My whirlpool LHW0050PQ4 washer door is locked and unable to open, wash cycle is finished. Unplugged overnight and return next day, still locked. Any suggestions?
Have tried new wash cycle - runs full cycle but door doesn't open; tried stop button but still doesn't open door.
Nitrotrike
  • 589 Answers
SOURCE: Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Posted on Jan 11, 2008
jsrock516
  • 5911 Answers
SOURCE: my whirlpool washer (Ultimate care
If the washer fills, but won't spin or drain, you may have a defective lid switch. This is a very common problem and a very common symptom.
Let me guess: The washer fills, agitates, but when it gets to the spin cycle it just stops. On some models the washer will fill and then shut off. Am I explaining your symptoms correctly?
If so, this what you need to do:
Open and close the washer lid and listen for a distinctive "clicking" noise. The contacts on the switch should close when the lid is shut, allowing the washer timer to run. This is a designed safety feature that prevents the washer from agitating or spinning with the lid open (don't need to lose any fingers). If you don't hear the switch, it may have come loose, or has broken.
Some lid switches are located on the right-hand side of the tub rim. There will be a slot where the lid strike pushes down on the lid switch. Make sure the lid strike (small plastic piece) is still present on the lid. This can prevent the washer from working as well and make it seem like a huge problem.
On some models the lid switch is located near the left-hand lid hinge under the washer casing. A small rod on the lid hinge activates the switch contacts.
If you determine the need to replace the switch, follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Good Luck.
Posted on Feb 27, 2008
  • 1314 Answers
SOURCE: whirlpool duet frontloading washer been
as far as i can find out there is no f35 hold pause cancel for three seconds and let me know if the code resets
Posted on Jan 30, 2009
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
  • 6 Answers
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
Posted on Jan 19, 2010
reset it
push sound for 10 secs
or
open top
spline screws top back
an reach down to the door latch
bottom of latch t is a small loop for your finger to pull/push it down
you can get to it same way from the bottom front cover
unplug unit
3 spline screws on bottom front washer cover
reach up an pull the loop on latch
good time to clean out the trap since your (t)here.
May 13, 2014 | Whirlpool Washing Machines
Whirlpool 6th sense stops at 1 min and doesn't finish wash cycle
We had same problem, and the only thing that we could do is call the repair man. He put in a new door lock and the problem was solved.
May 21, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Chain came off tracks...repaired it and now it will not run full cycle...only goes a foot or so and then stops
if your talking about a garage door opener , pull the manual release , drop the door all the way,, with the handle still disengaged,, push the button to drop the door,, latch the handle,, try that , if that doesn't work, you need to adjust the chain so that reaches the stops at the correct time, here is a video on it,, Good Luck http://www.ehow.com/video_8739813_adjust-chain-garage-door-opener.html
Sep 11, 2011 | Vacuums
After a power outage, the lid is locked and won't open. I tried running a new cycle but won't run either. Any suggestions. Thanks, Jan
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 11, 2011 | Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
De comes on the front and wont drain wm1814cw
the machine is clogged is th hose kinked,try to push the start buton again,you should hear the pump come on and try to drain.when it stops,push the button again,when the door unlocks take cloths out.And put 1/2c of bleach in drum and let it soak a few hrs.Now start washer no clothes this may do it,after cycle put clothes back in and run clothes through full cycle.When ther done.Put in Draino-Drain opener gell only and let it set over nite,then run heavy duty cycle this well clean washes and clean pump.
Jul 26, 2010 | LG WM1814CW Front Load Washer
The door on my Smeg Allegra front-loader washing does not open
SOME MACHINES HAVE A DELAYED OPENING TIME SO THE DOOR DOSE NOT OPEN WHEN BUTTON PRESSED LOOK IN MANUNAL TO SEE IF THIS FEATURE IS ON MACHINE IF NOT PROBLEM THEN NEW DOOR LOCK WOULD BE IN ORDER
Dec 30, 2009 | Washing Machines
Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Dec 08, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
