Question about Music
48 volt phantom power in a Yamaha MX200 mixer board does not work
3 Suggested Answers
  • 5603 Answers
SOURCE: Behringer XENYX 1622FX, won't power on. Phantom power works(?)
After reviewing the schematic, I don't understand how the Phantom power can REMAIN on with the power switch off... this CANNOT occur except for what energy is left in the 48 volt supply filter cap... This might last for minutes after the fuse went... UNLESS you have devices connected which are backfeeding the 48 volts. (which would be a disaster)
The 48 volts, +/- 12 volts and +/- 15 volts and the +5 volts ALL come from the SAME switching power supply. I suspect one of the filter caps went or the primary switching regulator a TDP245Y chip.
You should ONLY work on the line side of this using an ISOLATION transformer since the line side has lethal voltages.
To do testing, one replaces the fuse and puts a 60 Watt light bulb in series with the hot side of the inout line. The lamp "acts" as a resetable fuse and limits the current for testing. When all is well again, the lamp will remain out with the power flowing through it.
The D1 diode bridge and C7 input rectifier and filter are first things to check. You can do those with an ohmmeter.
I will caution you to ALWAYS power any and all equipment from the SAME power source. Plugging in devices from across the room will set up ground loops and any ground fault will fry equipment.
Posted on Apr 05, 2010
  • 5603 Answers
SOURCE: I have a Yamaha IM8.
There is really no way for a condenser mic to damage the board UNLESS you break the ground and get a static discharge into the input. That can happen with any microphone and has NOTHING to do with the phantom being on or off. As phantom power goes on and off slight bias at the input preamps can make amps non-linear causing the raspy sound you heard. The Phantom LED means NOTHING as it shows the state of the phantom switch by connecting a 12 volt source through a resistor to the LED... It shows NOTHING regarding the state of the 48 volt supply. Each input circuit has two 6.8Kohm resistors to the swinger of the phantom switch 2nd pole that either grounds those or connects them to a filtered 48 volt source. As long as you don't have a static buildup there is NO need to turn phantom power on or off while connecting a condenser microphone. At each input when using the XLR jacks are two per side 470pf capacitors for RF bypass. For the XLR's there is a 10Kohm between the signal lines and two series 10mfd/50 volt caps in series of each input to block the DC, when using phantom power, from reaching the preamp stage. These caps have to charge and discharge when changing the state of phantom power so you should AVOID having the main amps being driven while changing the state of any phantom power. Always have the fader(s) down and any monitors down to avoid a thump and also the non-linear raspy transition as the input caps charge/discharge. So fix the microphone... don't know what type you have, but DO check the cable (first) as ALL three conductors MUST be good for a condenser mic to work on phantom power. A ground leakage or noisy connection will cause your symptoms. Use a SHORT known good cable right at the board to test the mic. The 48 volts is applied through the two 6.8K resistors between both the signal lines to the shield of your XLR cable. The microphone picks off the 48 volts with a similar circuit.
Now let's cover a very important thing regarding system safety: ALL, and I do mean ALL interconnected equipment MUST be powered from the same source. Professionals run a power cord back to their mixer right alongside the snake. This is to avoid ground bounce damage due to bad building grounds or ground faults.
Posted on Mar 22, 2011
My Behringer XENYX 2442FX Mixer does not power up, the only light that comes on is the phantom power light. I opened it up and noticed that the switching power supply has multiple voltage outputs.
You should find +/-15 volts and probably +12 volts an +5 volts as well as the +48 phantom supply. If only one of these is missing, check the regulator for it... most are three terminal regulators. If the one that is missing has a hot regulator you have a short someplace and this requires skill to locate Probably the fastest way is to use a thermal imaging camera... however I have often used a millivoltmeter to find where the supply drops tpo near zero. Using a "calibrated" finger and search for a hot component on the circuit board can be very effective. Likely one of the surface mounted chips has shorted. Replacing these requires skill so best leave board repair to a skilled repair person as you can easily damage the board permanently.
Oct 04, 2011 | Behringer XENYX 2442FX Mixer
Dear sir i am phasing the problem of secondary voltage of transformer in power supply board . actually i am not getting the 48 volt(dc) at o/p .
I assume you are refering to the 48 volt Phantom power? check rectifiers, filter caps and the regulator. Find if the voltage is getting to the regulator.
Jun 16, 2011 | Soundcraft *new* Soundcraft Epm8 Analog...
I am using the SL 2442FX -pro, my question that if i turn on the phantom power switch and i'm using 15 dynamic microphones and only 1 condenser does it affect the performance of the dynamic mics?thank...
Your dynamic mics should be fine, phantom power provides one positive 48 volt potential to one side of the coil, and a negative 48 volt potential to the other side of the coil so your mics will effectively see 0 volts as these potentials will cancel each other out ( hence the name "phantom" power).
so provided that your microphones are wired properly internally, and your xlr leads are in good condition you will not damage any of your equipment.
I hope this has been helpful
Apr 03, 2011 | Behringer XENYX 2442FX Mixer
+48 volt in power supply is not working. All other voltages are present
Download the schematic at:
http://elektrotanya.com/mackie_1604-vlz_mixer.pdf/download.html
Scroll down to the link to download that says "Get Manual"
This is for the 1604 unit which is just a truncated version of yours. When downloaded, find the phantom power supply on page 18.
There are too many components to guess which one so best just to troubleshoot.
I would even suspect the phantom switch since they have POOR design with no inrush current limiting when charging the input capacitor. Since the 48 is not individually fused, if the inpout cap C3 shorts, it probably will take out the switch or the diodes.
Another user had the Zener D9 fail which would cause the problem. Meter the voltage across C3 (probably about 60 volts) and D9 and C4 (47 volts). First check C4 as that cap is run TOO close to the rating of 50 volts... poor design... C5 would also be suspect... or Q1 and Q2.
Then it gets dicey as there are UNDOUBTEDLY many bypass caps in the mixer portion of the board.
Apr 02, 2011 | Mackie 2404-VLZ3 Mixer
I have a Yamaha IM8. I had a condenser mic hooked into channel one with phantom power on. I had to leave the room for a while and when I came back, I noticed some rather severe popping in the audio. I turn...
Mar 22, 2011 | Yamaha IM824 24 Channel Mixing Console IM8...
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
What is the likely cause of the phantom power of a samson 900 mixer to go bad?
The phantom power is used for condenser mics. MAKE SURE you do not plug in other mics or devices that do NOT have balanced, isolated outputs as they will short out the phantom power to others.
You should find between 15 and 48 volts between BOTH pins 2 and 3 of each mic connector when measured to pin 1 of the connector. There is about 6K ohms impedance from the phantom supply to pins 2 and 3.
IF you have an accident and connected high voltage to pin 2 or 3 it COULD back up and blow the bypass cap for the 48 volts.
Please note: ALWAYS power ANY interconnected equipment from teh SAME receptacle to avoid damage due to ground bounce in the event of a fault in a piece of equipment.
Oct 22, 2010 | Samson Xm910 8Channel Powered Mixer...
My mixer wont power up. the only light that comes on is red led +48 v
This MAY be a power supply problem. We need to find if the power supply is putting out what it is supposed to. Using a meter, put one probe in pin 1 (ground) of one of the mic connectors, say channel1. Put the other probe in either pin 2 or 3 of another mic connector... Note we are using different connectors as there often isn't enough clearance for the probes in the same one... With Phantom power turned on and LED +48 lit, how much voltage do you read? If it is say 40 volts or more, then power supply is operating.
If the supply is operating then a POSSIBLE problem is a connector has fallen off where it connects to the supply or the main board.
The power supply provides several voltages such as 5 volts, 12 volts and 15 volts of various polarity.
If the 48 volt supply is found to be operating with the above test, then since the switcher and transformer are shared, it is likely the other voltages are available.
CAREFULLY open the unit and look for a loose cable.
PLEASE NOTE: This is a switching type power supply and part of the supply runs at power line potential. Only work on the supply if you are skilled and have an isolation transformer for your own safety.
Sep 21, 2010 | Behringer XENYX 2442FX Mixer
Apr 04, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Music Logo
54 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
