Question about GE Spacemaker JVM1640SJ Microwave Oven
Jvm1650sb004 how do i take off and clean vent on top front
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Jul 29, 2014 | Maytag MMV4205 Microwave Oven
HOW DO WE SWITCH FROM TOP VENT TO NON-VENT?
remove outer case and rotate vent fan motor to vent out front of unit
Aug 22, 2010 | GE Profile Spacemaker Over-the-Range...
Samsung SMV blower installation
Most Microwaves arrive ready to vent back into the room. For filtered air returned to the room it should face toward the front. For top vent, point to the top. for rear wall vent point toward the back.
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My whirlpool microwave was hooked up but doesn't seem to be venting out the roof. It has a vent running from the top of it through a cabinet and out the roof. What might be blocking the venting process?
the fan motor needs tobe turned around take screws out of top front remove front fan grill pull out fan assibliy and turn around. this will pull air out of your house
Sep 21, 2009 | Whirlpool MH7140XF Microwave Oven
Cleaning vent
two screws on top will release the vent to remove.
Sep 08, 2008 | GE Advantium 120 Convection/Microwave Oven
Clean vent
The vent (also known as grill assembly in GE literature) comes off after removing the two screws at the top of the unit and gently sliding the entire assembly to the left about an inch. This will allow the vent to be cleaned of grease, hair, etc., as well as giving some access to the areas behind the vent.
Dec 21, 2007 | Microwave Ovens
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
