Question about Cuisinart DCC-3000 Coffee on Demand 12-Cup Programmable Coffeemaker C
Blue light on machine won't work
Blue light on but coffee pot won't work
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: DCC-1200 coffee maker. I've
Most coffee makers use a small check-valve in the feed line to the coffee basket and if a small particle gets trapped in it, the pumping action becomes erratic or very slow. To be sure any lime deposits are dissolved, use < 1 cup of Lime Away or similar product such as CLR. Make sure there is no water left in the reservoir and pour the product into it. With no coffee in the basket and the pot in place, turn on the machine and watch for the first drops into the pot, then turn off the machine again.
Let it stand for a couple of hours (I'd recommend against leaving it overnight) and then turn it back on to let it finish pumping the reservoir empty. Check the sediment in the bottom of the pot and if you see any 'crud' such as particles of lime or even a granule of coffee, you may have solved the problem.
If that seems to be the case, flush the machine with a tablespoon of baking soda and then clear water.
Good luck-
Posted on Jul 08, 2011
Coffee pot won`t turn on.It`s getting power because the clock is running and the 1 to 4 button lights,but when I toggle it to on the red light does not come on.
It is possible the heating element is burnt out, or the safety fuse has been fried and is opened not allowing power to the element.
Sep 10, 2014 | Cuisinart Coffee Makers & Espresso...
Why won't the hot water empty into the coffee pot?
Make sure your caraffe has its lid on , and check the bottom of the filter. it usually has a valve preventing coffee from leaking when you remove the caraffe. the lid pushes the valve back open when you place the caraffe back into the machine.
Jul 10, 2012 | Cuisinart DCC-2200 14-Cup Coffee Maker
Cord for corning ware coffee pot 10 cup cornflower blue
Hi. Go on to eBay and search for corning coffee pot parts. I've seen them. Good luck. Ron
Apr 11, 2010 | Coffee Makers & Espresso Machines
We have had our WC1000 coffeemaker for 6yrs and have had no problems with it until recently when the blue light does not go out and the green light does not come on at all. It still heats up the water and...
chances are your pot is a bit clogged with coffee oils. I would run a couple of cups of vinegar through it followed by three pots of water to attempt to remove those oils.
Oct 04, 2009 | Waring Pro WC1000 Coffee Maker
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
Cuisinart DCC-3000 Coffee on Demand 12-Cup Programmable Coffeemaker C Logo
18 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
