Question about ION Audio Tailgater Portable PA System Speaker System for iPod
Remove the case on ion tailgater amp - ION Audio Tailgater Portable PA System Speaker System for iPod
My ion tailgater will not charge I have a 12v batt 8 ah will this work?
probably not but all you lose is the battery or the tailgater
Feb 10, 2015 | Drills
Just bought an ion tailgater and the microphone has no sound. Just wondering if it could be something besides a bad mic?
It could be a bad mic cable or connector. If it is a cheap mic cable, then the chances are very good that the cable has shorted internally. If the mic works on something else, then it is possible that there is a setup function that you have to turn on/off for the mic to work.
From what I can see from your photos, I would bet on a low quality MIC cable.
Oct 18, 2014 | ION Ipa17 Iphone[r]/ipod[r] Tailgater...
How to change the auxiliary input on an ion tailgater
Yo. This same thing happened to me. It sounds rudimentary, but I just superglued toothpicks onto the broken ends (obviously being sure not to get glue on the jack itself) and after waiting for them to dry, I just yanked them out by the toothpick. Worked like a charm. Good luck!
Apr 02, 2012 | ION Audio Tailgater Portable PA System...
No sound on the tailgater
My tailgater is from the US, and I live in NZ. I changed the voltage to NZ and while the unit did work straight out of the box, after a month of me not using it, it now no longer has any volume. I have tried all the knobs but thats as far as my knowledge goes! Does anyone have any solutions I can try? thanks!
Oct 24, 2011 | ION Audio Tailgater Portable PA System...
How to remove the lead acid battery
Very Easy!!! i just replaced mine yesterday, In the bottom of the tailgater there is a cover plate with 4 screws. Unscrew them and pull battery out, unplug the positive and negative cables attached to battery. Take Battery to an Electronic Store and ask for replacement battery. These batteries are also used in back up home alarm systems so they're pretty easy to find. i found mine at radioshack. Now to install, easier!!! plug in power and ground cables to battery, slip battey back into pocket screw back on plate, and charge for good 4-6hrs. and voila!!! you'll be bumpin in no time!!!!
Feb 22, 2011 | ION Audio Tailgater Portable PA System...
I bought the ION Tailgater in USA but I live in Argentina where the input voltage is 220W. I uncovered the cap behind the device and the switch of 110-220 was there, my question is should this work??? (I'm...
You should have no problems.
I live in Australia, with 240 VAC, and we see this type of thing a lot.
Put the cap back on once you have switched it.
I have seen a computer power supply that was accidentally switched back to 120 as the switch had no cover.
Jan 28, 2011 | ION Audio Tailgater Portable PA System...
I have an ION Tailgater which doesn't seem to be charging. The unit power doesn't have to be on whilst charging, but approximately five seconds after plugging in to charge, the charge light goes out, and...
I just bought four units, 2 of them work fine but the other two have problem, but one of the unit did get charged up even without the charger light on. I switch on the unit, leave it plug in for a few days and the unit come back charged. I try with the other one, but it is not working.
Dec 20, 2010 | ION Audio Tailgater Portable PA System...
Broken tailgate latch
Remove the paneling from inside. Than you can use a flathead screwdriver to pry the latch rod and latch enough to pop open the door.
May 23, 2009 | 1996 Chevrolet Blazer
Need instructions on how to install a new tailgate handle, 2003AV
Here is a video I made http://www.youtube.com/watch?v=ChC2J5MFfKI BASED OFF INSTRUCTIONS FROM www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0CIEBEBYwBA&url=http://www.chevyavalancheclub.com/index.php?action=articles;sa=view;article=96&ei=mAwJUL7BBqnq2
EASY FIX, $100 out the door buying all parts, tools, and locktite
May 12, 2009 | 2003 Chevrolet Avalanche
2005 Honda Odyssey Tailgate Problem
Try to reset the tailgate by removing the no.7 (7.5 amp) fuse in the underdash fuse box. Open and close the tailgate manually, reinstall the fuse, and try the open tailgate button. If that doesn't work you would have take it to the dealer, where they can check for DTC's (diagnostic trouble codes). Honda Al
Apr 12, 2009 | 2005 Honda Odyssey
ION Audio Tailgater Portable PA System Speaker System for iPod Logo
29 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
