Question about Brother IntelliFAX 2800 Laser Fax
I have a brother 4750e fax that is sending occassional barcode looking black areas on the right side of page. receives OK Has new drum and clean scanner glass
  • Brother Expert
  • 159 Answers
My first guess is a bad drum unit. Inside the assembly is a soft, plastic blade that scrapes off the toner that didn't make it onto the paper, so the next page will be clean. If dirt is stuck under the cleaning blade, it may skip, making marks like that on the drum, which get transferred to the page.
Do you still have your old DR-400 drum, or can you borrow one from another machine? Swapping drums is the ideal test, if you can avoid buying a new one. If your new drum is bad, the seller should exchange it.
Posted on Aug 05, 2009
My intellifax 4100 has a wide solid black bar approx 1 1/2 wide down the entire right hand side of the page of faxes that I send. (faxes that are received by others). The machine works perfectly in every...
Here is a list of possibilities.
1. The scanner glass is very dirty on one side. (the area the paper paasses over.)
2. The laser scanner lens is dirty on one side
3. Look in the bottom of the machine and locate any mirrors and clean with a dry soft cloth.
You will need to remove the drum and toner to do this.
Feb 23, 2011 | Brother IntelliFAX 4100 Laser Fax
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
When we send and receive faxes via our Brother Intellifax 4750e, there is a large black line on the right of the page.
hello, if this line is larger than 1 inch, and you already checked toner and drum, then the problem will be the actual scanner, this unit will need to be replaced,
Sep 29, 2010 | Office Equipment & Supplies
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Right side of printed page is faded
pull out your drum unit and look inside machine above where the drum would be. you should see a black assembly that runs left to right with a "****" glass. may need a flashlight. clean that glass off with a clean rag. sometimes toner "scatter" will get on glass and cause this.
let us know,
razors
Mar 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Black border down the right side of the page, which blocks info
either you neede a new drum or this is problem in the fuser section. may be baf heater roller. try cleaning the grid on the drum cartridge with a soft bristel pauint brush good luck brother sr tech
Jan 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Sending Inverted Image
do you mean that the blacks are white and the whites are black? do they look like a negative. if the aswere is yes it siund like you have dirty drum contacts when you take the drum unit out look on both sides of the drum cavity for contacts and clean with a pencil eraser. then clean the drum unit grid,
brother tech
Jan 16, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 2800 Laser Fax Logo
172 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
