Question about Rowenta Pressure Iron and Steamer DG5030
How do I replace a fuse in rowenta steamer
While ironing, power went off on iron. Switch does not operate. I opened the casing to evaluate fuses. What do they look like, and where are they? Can I order them and replace them myself?
4 Suggested Answers
DiYerTech
  • 70 Answers
SOURCE: steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Posted on Jul 02, 2008
  • 24 Answers
SOURCE: Rowenta iron
Dropping any iron is the kiss of death... dont use it again, especially on the steam setting.. you could electrocute yourself..
Dispose of it safely and get a new one. You wont make that mistake again in a hurry... I didnt!
:o)
Posted on Aug 03, 2008
heatman101
  • 43501 Answers
SOURCE: IRON WILL NOT HEAT UP, LIGHT DOES NOT COME ON
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Rowenta pressure iron and steamer model DG5030? We have purchased the iron and cord, now we need to assemble the part.
Google Rowenta and go to their website, they will have parts diagrams and wiring diagrams. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 30, 2014 | Irons
Rowenta Dz9080
Check or replace fuse in plug. If that don't do it, then change fuse inside iron. Make sure iron is not plugged to supply.
Apr 28, 2013 | Irons
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
The power to heating section suddenly went off. Is there an internal circuit beaker or fuse?
check your power cord if it has a break from the plug side.if not take it to a repair shop for repairs. the steamer has a element inside that gives off the heat if that goes bad then there is no where it can be replaced or repair.but if its the wires then repairs can be made.best way to know that is to take it to the repair shop.good luck.
Sep 23, 2011 | Rowenta Commercial Garment Steamer - White
How do i open d rowenta garment steamer to change the fuse or burnt wires
There are four screws (Phillips) but you need long thin screw driver to remove them. Then there are TWO screws underneath the Castors. Just pop the Castors and turn them and you will see the screws. BTW there are two fuses inside. One you can replace and the other one is soldered in and you need to be little skilled to replace it. Chances are if the first one blew the second one should be OK. Good luck.
Jul 04, 2011 | Rowenta Commercial Garment Steamer - White
Model dx6250 just quit working while my wife was ironing. What Happened? No sparks or nothing going on cheked power cord and it gets juice to the control but nothing beyond that.
Hi rhmoreno,
The fuse in your iron might have sacrificed itself to save you and the iron. :)
Replacing the fuse with the exact same will solve your problem but for which you will have to open the iron and thoroughly scan it to find the fuse.
hope i solved your problem, if i did then please vote for me and rate for me too :)
Regards,
Salman
Feb 11, 2011 | Rowenta Irons
I GET NO HEAT IT JUST STOPPED
U got a busted thermal fuse or the thermostat switch is not functioning.
If u have a knowhow in replacing and adjusting the thermal switch, u could fix it by urself!
Better check also the power cord, mostly flat irons main prob, if there are no lights on ur iron, it means internal probs!
Better take that iron in ur friendly hungry technician to fix that!
Dec 02, 2010 | Rowenta Professional DE880 Iron
Iron won't heat up
Fuse gone, Break in the supply cable or both
If there are no indicator lights on the iron I would check out the fuse first if that is ok then I would waggle the power cord where it goes into the strain relief grommet just before it goes into the iron body.
If you get a connection then it is a case of stripping down the iron and re-wiring the cable
Jan 05, 2010 | Rowenta Irons
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Jun 10, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Pressure Iron and Steamer DG5030 Logo
175 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
