Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
Why does pool sweep tilt on it's side? - Polaris 280 In - Ground Pool Cleaner with Booster Pump
    Top Expert:
  • Polaris Master
  • 5,051 Answers
Check ballast ball if water inside replace
Posted on May 22, 2016
2 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: Pool sweep wheels are not turning...
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
Posted on Mar 30, 2011
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
The sweep tail doesnt sweep
Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. You might also need to adjust the screw that holds the sweep hose in place. If it is too tight it will not have the slack to move. If it is too loose, it will not have enough tension to move. Try adjusting it and it should have the pool cleaners sweep hose motion.
Mar 14, 2011 | Pentair White/Gray Legend Platinum...
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
Moves slowly and the stops. looks like diapham doesn't open back up
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
Nov 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
After two years of perfeft performance, the Legend Platinum start to misbehave. Whells runing at 23 to 25 RPM after cleaning the hose filter. Main pool filter runs at 23 psi, booster pump runs and pressur ...
If your RPM is low, you will need to increase pressure to the cleaner. If the sweep hose is laying on the side and not sweeping, you will need to adjust the screw that holds it on to get it to a gentle sweeping motion. It is also possible that you have too much hose weight on the pool cleaners sweep hose. Try removing some of the weight and seeing if that changes.
Sep 14, 2010 | Pentair White/Gray Legend Platinum...
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Calcification on swimming pool
Size the gallonage of your pool and purchase Scaletec. Double to dose. 4 to six weeks the scale will dissolve and brush off
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
