Question about Refrigerators
WHERE IS THE DEFROST TIMER SITUATED IN A WESTINGHOUSE BJ505
WHERE IS THE DEFROST TIMER SITUATED IN THE WESTINGHOUSE BJ505
3 Suggested Answers
  • 190 Answers
SOURCE: defrost timer
Dear customer,
       The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
     To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
          The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
emissionwiz
  • 80263 Answers
SOURCE: I need a wiring diagram for the RJ532S freestyle westinghouse fridge. The defrost timer is dead and its in defrost mode
We do not have wiring diagrams. Please contact the manufatuer for a service manual
Posted on Feb 02, 2012
Hi, I have a similar problem with my fj383 and I also turned the knob down he back on the left hand side. Now i just have a timer type sound coming from that box and the freezer not running. thankyou
I did not quite understand your question, ... "I have a similar problem?"
DO a GOOGLE SEARCH for: "Westinghouse fj383" freezer troubleshooting and find 1,260 results!
westinghouse fj383 freezer troubleshooting Google Search
Then do THIS GOOOGLE SEARCH for even more!
"westinghouse fj383" manual (WITH the quotes)
westinghouse fj383 manual Google Search
1,300 results ~ but many may be duplicates?
Then this interesting (to me) GOOGLE SEARCH in "IMAGES" for "westinghouse fj383 wiring diagram".
westinghouse fj383 wiring diagram Google Search
... where I found THIS part:
There is NOT that much (electrically speaking) else that would make the sounds you describe!
Looks like a Frigidaire Refrigerator Defrost Timer 215846604 may be the puppy you need for about $8 plus shipping OR
Defrost Timer for White Westinghouse WWTR1502KW7 Refrigerator
HOPE this helps!
Anthony
(say Thank You!)
Apr 17, 2018 | Refrigerators
Where do I find the defrost timer and main thermostat in a Westinghouse Virtuoso RS643T side by side fridge?
Go to www.repairclinic.com and enter RS643T. With luck, you will be presented with a list of common replacement parts and may be able to view a generic disassembly video showing parts location.
Dec 14, 2017 | Westinghouse Refrigerators
Why fridge westinghouse model bj505 keeps filling up drip-pan?
check the fridge doors seals. make sure doors seals against the frame. check condenser and clean by vacuum or bottle brush.
watch out for conderson fan motor
May 25, 2014 | Refrigerators
Defrost timer
The defrost timing is controlled by a pc board. This model doesn't have a standalone mechanical timer. If you have a defrost issue it is likely to be the element or termination sensor.
Jul 10, 2013 | GE GSS25LGM Side by Side Refrigerator
My defrost heater is not working. Westinghouse
You did not mention if your unit was 120VAC or 220VAC parts replacement mandate you know exactly which it is your searching for as far as replacement part sources.
120VAC US parts source
220VAC UK parts source
Most often a Defrost problem is one of the following:
1. Defrost timer (there are 4 terminal timers MECHANICAL and Multi terminal ELECTRONIC timers) Any generic Defrost timer will work as long as you know the input voltage and the number of require terminals match.
2. The 60 Deg Thermostat
3. The actual heating element
This company ships international USPS
Welcome to A-1 Appliance Parts We are the ultimate source for the do-it-yourselfer appliance repair person. USA Phone 1-800-841-0312
Here is a link to multiple Defrost timer examples. You should be able to match yours up with the images on this page. It may take a while but you can do it.
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=Defrost%20timer&ST=BIP
After a US Westinhouse search I get the feeling you may have to do a web search for "appliance repair parts UK" I hope this was of some help. (Last time I was in your area was 1997 US Navy....)
Jan 28, 2010 | Westinghouse Refrigerators
Location of defrost timer for frigidaire side by side
REMOVE BOTTOM FRONT TRIM UNDER FRONT DOORS
THE TIMER I BELIEVE IS ON THE LEFT SIDE YOU WILL SEE TWO PHILIP SCREWS REMOVE AND UNPLUG THE WIRE HARNESS FROM TIMER AND VOILA!
Jan 19, 2010 | Frigidaire Defrost Timer 215846602 ...
Where is the defrost timer located on a Frigidaire model # FRS24WNF?
its a defrost trermostat located near the evaporator coil and defrost heater coil
Oct 24, 2009 | Frigidaire Defrost Timer 215846602 ...
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
