Question about Polaris 380 In Ground Pool Cleaner
How to fix sideways pool sweep? - Polaris 380 In Ground Pool Cleaner
    Top Expert:
  • Polaris Master
  • 8,177 Answers
Thruster points at 11:00
Posted on Dec 18, 2017
2 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: Pool sweep wheels are not turning...
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
Posted on Mar 30, 2011
How to fix the polaris pool sweep tail problems
there is a plastic clip you can use a zip tie if you cannot find it in the pool
Aug 16, 2014 | Polaris 280 In - Ground Pool Cleaner with...
How to fix a polaris pool sweep tail from coming off
there should be a clip that holds it on probably in bottom of pool or in the bag
Aug 16, 2014 | Polaris VacSweep 280 Pool Cleaner with...
How to fix sideways Polaris pool sweep?
check ballast ball on top if water inside replace
May 13, 2014 | Polaris 380 In Ground Pool Cleaner
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
The sweep tail doesnt sweep
Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. You might also need to adjust the screw that holds the sweep hose in place. If it is too tight it will not have the slack to move. If it is too loose, it will not have enough tension to move. Try adjusting it and it should have the pool cleaners sweep hose motion.
Mar 14, 2011 | Pentair White/Gray Legend Platinum...
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
Moves slowly and the stops. looks like diapham doesn't open back up
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
Nov 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
After two years of perfeft performance, the Legend Platinum start to misbehave. Whells runing at 23 to 25 RPM after cleaning the hose filter. Main pool filter runs at 23 psi, booster pump runs and pressur ...
If your RPM is low, you will need to increase pressure to the cleaner. If the sweep hose is laying on the side and not sweeping, you will need to adjust the screw that holds it on to get it to a gentle sweeping motion. It is also possible that you have too much hose weight on the pool cleaners sweep hose. Try removing some of the weight and seeing if that changes.
Sep 14, 2010 | Pentair White/Gray Legend Platinum...
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 380 In Ground Pool Cleaner Logo
52 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
