Question about Husqvarna 124L 28cc Gas Line Grass Lawn Trimmer Refurbished
How to lub husquvarna 124l shaft? - Husqvarna 124L 28cc Gas Line Grass Lawn Trimmer Refurbished
My scania 124L. I change the clutch plate. Have no clutch , I cant see the bleeding niple.
Some don't have a bleeder. You just have to pump the pedal till the pressure builds up.
Aug 28, 2016 | Cars & Trucks
Seat on my 2002 pride victory scooter will notcom out of shaft.
Is there a set screw in the bush the seat shaft goes into? If not it could be a burr on the shaft which means you may have to use a bit of brute force to pry it out. Check for screw or pin first.
Oct 20, 2014 | Health & Beauty
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
Fix my gas cap door
push the fuel door button,if you hear the door trying to open,[or close]
the cable shaft is not free. In the trunk,just behind the cap door,
you will find it,spray it with a good lub. you can move this shaft with
your fingers.
Feb 23, 2011 | 2003 Buick Park Avenue
What type of lubrication maintenance is needed on the husquvarna 450-e chainsaw?
Grease your shaft bearings once a year helps.Isnt necassary but will help.Other than that just keep bar oil in it.
Jan 02, 2010 | Husqvarna 450 e-series 18" Chain Saw
The gear shift, (on the steering column) has become stiff. It still works but is stiff.
The gear change at the end out side the fire wall goes back to a x shaft and on to the side of the auto box, so take off the Gear box end and then try it,If still stiff then its due to lack of lub (oil) so lub with engine oil on all bushes and under the Steering wheel, play with it till free an easy.
Reconnect and test run.
IF its free then the problem is in the Auto-Gearbox and thats a lot more
of a problem and you either have to get it done be the Auto box shop or try it your self,and thats a shaft that goes into the valve body housing
in the pan and thats a big job,not the sort of thing you want to try
beleave me.Let me know how you get on RON
Nov 02, 2009 | 1997 Cadillac DeVille
Husqvarna 124L 28cc Gas Line Grass Lawn Trimmer Refurbished Logo
13 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
