Question about Compaq Computers & Internet
The tray of cd rom keeps on opening and closing by itself repeatedly.. how do i fix this? plz help
  • 55 Answers
Try changing the settings of your cd-rom device from the BIOS SETTINGS....
Good Luck.
Posted on Jun 23, 2009
My cd rom tray does not open
hit it on top of it or the casing and it will open. but this is not the good way but i have the same problem i use this
May 20, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
regards
3rq8 (Triarcuate)
Mar 31, 2009 | Sony CDP-C265 CD Player
SGI O2 CD-ROM drive tray repeatedly opens
I am having the same problem. I haven't resolved it entirely, but at least I managed to get it working again by the following steps.
First, disassemble the part of the computer chassis around the CD-ROM drive. Follow the instructions for "replacing the CD-ROM drive" in the SGI 02 hardware maintenance manual. It can be done in 10 minutes with a screwdriver.
After you have gained access to the CD-ROM drive itself, take off the top metal cover. Then you will be able to see the tray and the white gears underneath.
In my case, the problem seems to be caused by some misalignment between some wire springs and the white gears. Note when the CD tray closes, the manual eject button (a black plastic rod on the right) should stick out, and the white piece of plastic with a triangular end on the left should push against the front of the CD tray.
Somehow, the gears failed to push the white plastic piece all the way to the edge of the tray, and the CD-ROM drive thinks the tray wasn't fully-closed, and ejects the disc.
To force the drive to read the disc, pull the white plastic piece on the left with the triangular end towards the edge of the tray. (Pull it towards you if you are facing the front of the drive.) You might need to use some force, but I can get the drive to work this way, even though it still "sticks open" half the time.
Good luck, and if you happen to find a better solution, I look forward to hearing it.
Jan 07, 2009 | SGI Silicon Graphics (P-CDR32-EXT) CD-ROM...
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Door
Hi abdu
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
Hope this helps
Cheers
Deon
Sep 10, 2008 | LG (GCE-8527B) CD-RW Burner
Problem with samsung x 05 cd rom
It sounds broken but as a last ditch effort I would try disabling it in device manager and reenabling it.
Jul 11, 2008 | Samsung X05 Notebook
DVD-ROM
LS-120 SuperDisk drive help The LS120 will not work off a sound card IDE channel. ... If the computer is on, however, does not eject and you are running Windows 9x.
CD-ROM tray not opening See document CH000885 for additional information about why the CD-ROM or other disc tray ejects by itself or does not close.
CD or other disc tray does not close or opens by itself.
Good Luck, read and folow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | Toshiba A15-S1292 Notebook
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Computers & Internet Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
