Question about Samsung Clothes Washer Drain Pump Assembly - DC96-01414A
How to get PUK code for samsung galaxy exhibit for free
  • 943 Answers
SOURCE: i need puk code samsung galaxy S at&t
can get it by contacting network provider customer care.....call from another number of same network.
Posted on Oct 29, 2011
  • 23 Answers
SOURCE: free unlock codes for samsung galaxy Gio
Free codes does not work some times..So better you will get the code from http://www.mobileunlocksolutions.com/ .It helps to unlock your samsung mobile easily.
Posted on May 09, 2012
conceptpromo
  • 4 Answers
SOURCE: NEED PUK CODE FOR SAMSUNG GALAXY APOLLO GT-i5800
contact the the airtime provider
Posted on Sep 17, 2012
SOURCE: Samsung Galaxy S2 manual
PUK is a safety code of your SIM card. It has nothing to do with your phone. You need to look for the envelope / bag / box that your SIM came with.
Posted on Mar 30, 2014
vansheene
  • 309 Answers
SOURCE: i need my samsung galaxy s4 work in other country, i need free unlock code.
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Posted on Jul 04, 2014
Can u find me a code to unlock Samsung galaxy exhibit IMEI 359874041306247. THANKS
Hello. You can definitely unlock your T-mobile network locked Samsung Galaxy Exhibit using unique unlock code. You can get the unique unlock code for your Samsung Galaxy Exhibit from Mobile-Unlocker.com at affordable cost with an easy unlocking guide. But you can unlock a GSM network locked phone to use any other GSM network SIM card only. Verizon is CDMA network provider. You cannot use it with the unlocked phone.
Feb 11, 2015 | Samsung Cell Phones
Free galaxy exhibit sgh-t599 t599 phone unlock to switch from tmobile to at & t
Hello. You can unlock your T-mobile network locked Samsung Galaxy Exhibit safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy Exhibit from MobileUnlockSolutions.com at affordable cost with an easy unlocking guide. Good luck.
Nov 05, 2014 | Cell Phones
My Samsung galaxy exhibit 2 4g model SGH-T679 keeps saying network lock key I dont know the code can you help?
Hi if you need network unlock code you can visit this site Simpleunlocking.com here you can get the code and unlock your samsung galaxy exhibit 2 4g easily. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email. Getting the free mobile unlocking instructions from this site. This instructions is very useful to unlock your mobile.
Mobileunlockguide.com
May 13, 2014 | Cell Phones
Need puk n pin unlock code for galaxy exhibit sgh-t599n
PUK and network unlock codes can be provided by your network provider only. There are certain online vendors like Mobile-Unlocker.Com who provide network unlock code at affordable cost. You can try through them. Once you have received the unlock code, you can visit MobileUnlockGuide.Com this site provides free unlocking instructions. This could help you unlock your Samsung Galaxy Exhibit yourself easily. Good luck.
Apr 23, 2014 | Samsung Galaxy Cell Phones
Cant unlock my galaxy exhibit from t-mobile want to use att simcard
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 31, 2012 | Samsung Galaxy S 4G Cell Phone
I want to unlock my samsung exhibit cell phone how do i do it for free
Aug 28, 2012 | Samsung Exhibit II 4G
I have forgot my unlocking code for my Samsung galexy ace its a patern code on freepay network. Can you help please.
root your phone,download the z4root,then download they samsung galaxy unlocker,all avalabile from www.phoenixtec.ca for free
Jun 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
Samsung Clothes Washer Drain Pump Assembly - DC96-01414A Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
