Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why does my john deere rx 73 have no battery but a key with start and run
3 Suggested Answers
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
SOURCE: John Deere 318 won't start. Replaced starter/alternator.
I don't think it's electrical. The starter gear gets jammed against the teeth on the flywheel. Try tapping the edge of the gear with a drift of some kind then try starting again. It won't solve the problem long term, but it will save you spending time troubleshooting an electrical problme that doesn't exist.
Posted on May 04, 2010
My Z trac john deere mower will not start. You turn the key and it just make a clicking sound.
Check the battery. If you have left it out with key on they go dead. Mower battery are not known to last more than 2 years.
Jul 18, 2017 | John Deere Garden
John deere tractor won't start ......turn key and just here one click. the tractor was running fine then it stalled out when i got stuck in mud.
check the solenoid to be sure it is good. possible bad connection at battery or a ground. be sure the battery is good.
May 26, 2017 | John Deere Garden
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere 170 with a kawasaki 14hp engine. Battery has 11 volts. I turn the key nothing happens when I jump the solinoid the starter hums. Any help is greatly appreciate
Battery is low. Either the battery is bad or the charging system is bad. You should read 12.5 volts or more when not running, 14 volts when running.
Mar 29, 2016 | John Deere Garden
My John Deere 1023e had a dead battery now it won't start
Sounds like the battery is discharging somehow. I would check to see if the key that starts it and controls the headlights is left on and allowing the batter to discharge.
Mar 01, 2015 | John Deere Garden
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LA140 won't turn. New battery. No sound when I turn the key. No headlights, what should I do?
Check your connections at the battery. May have a bad ground or bad battery connection. Also check to make sure new battery is good by supplementing with a jump start. If new battery is good and connections are solid, you most likely have a broken wire somewhere. The lights may only work with the mower running though. I believe on my LA105 the lights only come on with the engine running and dim/brighten with the RPM of the engine.
Apr 07, 2013 | Garden
John deere model240 mower will not start. Have replaced coil and still not getting spark at the plug . Engine turns over strong
Only option left.... 12 volts feeding coil is not there. The ignition key applys the 12 volts to the coil in the "Run" and "Start" positions. Verify 12 volts at input to coil and then (if needed) follow wire back to key and confirm voltage there....and (if needed) follow input wire to key from battery. One of those critters is open - since you have already confirmed the coil/spark plug wire is not at fault.
Dec 15, 2011 | John Deere Garden
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Repair manual for john deere rx85
rx85 johndeere rider turn key to run poisition in neutrual no contac to starter from ign. switch new battery fuse not blown
May 30, 2010 | John Deere Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
15 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
