My telefunken tv turns on but when I try and change the channel it turns off
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Telefunken LCD TV
As far as I know the only way to set lock mode on/off is using the remote.
The only thing I can think of is unplugging power cord for five minutes to check if this reset settings.
You can get a remote here :
Remote controls for TELEFUNKEN
Posted on Aug 14, 2008
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
What is the code for a universal remote in order to tune telefunken mp514 tv
These are the universal remote codes for Telefunken Brand TVs: 0031 0000 0001
Try this method, if none of above codes work.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
If you wish to get more details check this.
Dec 31, 2012 | Televison & Video
My telefunken tv has a lock displayed on screen and it only plays one channel, can't switch to other channels or do anything. Tv model is TTV-29SX, please help.
Consult the owner manual which should have instructions to clear that or Call Telefunken with the model number and have them step you thru the process.
Apr 09, 2012 | Samsung Televison & Video
I have q universal remote control URC33B i need the remote control code for a telefunken tht 160b dvd player
Hello
Just check with these codes, which are meant for Telefunken with URC remote control.
067, 075, 098, 132, 133, 134, 135, 140, 185, 186, 231, 235
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Jan 31, 2011 | Televison & Video
Looking for telefunken tv (MR702) user manual
I am looking for the user manual for this telefunken MR 702
Mar 14, 2009 | Televison & Video
Telefunken TV
there is an internal problem the memory of your tv was broken you need to go to one authorized service
Dec 10, 2008 | Haier HTF27R11 27" TV
Telefunken LCD TV
Aug 14, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
