Question about Eureka AirSpeed Bagless Upright Vacuum, AS1000A
Why eureka as1000a won't turn on
Shut off
Bissell powersteamer powerbrush keeps shutting off
Something is shorting out. Take it to a qualified professional
Feb 28, 2014 | Vacuums
Hoover vacuum shuts off after 10 minuts of use.
If there is no clog the filters may need replaced to improve airflow
Jan 21, 2014 | Hoover Vacuums
Eureka multicyclonic keeps turning off
Start by replacing the filters. If it's clogged the motor will shut off because it gets hot
Jan 21, 2014 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka vaccum won't turn on
There is a thermal reset in the motor that will shut the motor off if it gets too hot from a clog or clogged filters. It will come back on when it cools down. If it does this try to find a clog somewhere and also replace or clean your filters
Dec 18, 2013 | Eureka 5892AVZ Bagless Upright Cyclonic...
No power shut off while running.
Could you please rephrase your question. I don't understand it. If you mean that the vacuum won't shut off, just pull the plug. Joking. It's in the switch, that will have to be checked, cleaned and maybe replaced.
Oct 15, 2013 | Dirt Devil Vacuums
Turned off can not restart
it has an auto shut off feature if the motor gets to hot try unplugging it wait 30 mins then try again
Jun 02, 2013 | Eureka AirSpeed Pet Bag Upright Vacuum
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
Eureka AirSpeed Bagless Upright Vacuum, AS1000A Logo
122 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
