Question about Sharp Heating & Cooling
High cool mode of CRMC-A764JBEZ - Sharp Heating & Cooling
Flashing light the at says e6
Usually Indoor Unit Anti-freezing protection (Cooling
Mode) or Over-heating Protection (Heating Mode)
for Evaporator
A) Indoor room
temperature too low
under cooling mode,
Too high under
heating mode
B) Indoor unit filter or
evaporator too dirty
C) Indoor unit fan motor
blocked
D) Insufficient refrigerant
under cooling mode
E) Indoor unit evaporator
sensor wrong
connection or failure
Jul 28, 2014 | Samsung AQV12VBE Vivace Wall Heat Pump Air...
Can the unit operate without the remote control
Yes, by pressing the power button on the unit. It is factory set to cool to 68 degrees and maintain that temperature. To access any other settings you must use the remote control. The part # for the remote is CRMC-A750JBEZ
Aug 14, 2013 | Sharp CV10NH Air Conditioner
What costs less Dry Mode or Cool Mode on an Inverter Unit?
Use Dry Mode. Saves on ur bill and cools just fine.
Jul 03, 2012 | Mitsubishi Heating & Cooling
User manual for sharp CRMC-A562JBEZ
my air-con remote control was out-of-order. How can I buy one in Hong Kong for replacement. My air-con model is SHARP CRMC A562... Thanks to acknowlege to my e-mail jimjimtsim@gmail.com
May 11, 2011 | Sharp Heating & Cooling
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
What does the mode button do?
The mode button can be changing it from low speed to high or if it is a heat-pump, from heat to cool. Normally, its the mode you want to run it in, if its only an a/c unit, it would have to be low cool, med cool, or high cool. Its unfortunate you have misplaced the manual as it can come in handy for trouble-shooting in the future. I would go back where you bought it and say it didn't come with one.
Sincerely,
Shastalaker7
Jun 09, 2010 | Kenmore 75085 Air Conditioner
I have a 8 years old window ac. It's working quite ok. I just want to know which mode is safer low cool or high cool when humidity is high but temp. is about 32-34 degree celcius. Technican advised me to...
Its not a mater of safety. Its only a matter of witch is best for you. If you want to maintain the temp then leave it on low temp. If you want to save money then you can switch it to power saver mode on high to bring the temp down. Hope this helps. Good luck.
Aug 10, 2009 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
