Question about Car Audio & Video
How do i reprogram my eclipse avn1106mkii model radio?
Radio worked, battery replaced, radio light up but does not work?
assuming it displays the message "sec"; eclipse models use a securty cd to generate an new temporary security code and let you unlock it if you have that cd it ok but if not you have to get it or get the whole module serviced at your local eclipse dealer...
Apr 25, 2016 | Mercedes-Benz S-Class Cars & Trucks
Eclipse avn6606HD radio from japanese to english
It is possible to do this, although it is not easy. It requires reprogramming the HMI in the unit. I am in the process of doing this on my AVN6606HD and it would probably apply to other units to convert from japanese to english.
Feb 21, 2013 | 2007 Volkswagen Polo 1.6
I need to remove and replace the Radio in 2003 mitsubishi eclipse
I WOULD LET THE DEALERSHIP REPLACE RADIO BECAUSE BY IT BEING PART OF THEFT SECURITY SYSTEM.IF YOU DO IT YOUR SELF YOU PROBABLY GOING TO HAVE NO START PROBLEMS.THE PCM WILL GO IN THEFT MODE THINKING SOMEBODY TRYING TO STEAL RADIO OR CAR.IF DEALERSHIP FIX THEY PUT IN NEW RADIO THEN REPROGRAM IT.
Mar 31, 2010 | 2003 Mitsubishi Eclipse Coupe
I took out my car battery and now my radio needs reprogramming. where can I get the software online.
car batteries **** when you do that because it erases everything like you said,,,before you take your battery out go to the nearest car store like auto zone,,advanced auto,,etc ask them for the 9 volt battery plug in for the memory of your radio....it plugs in to your ciggarett lighter....to answer your question i worked at a dealership and its a dealership problem
Feb 17, 2010 | Eclipse AVN5495 Car DVD Player
I have a 2000 eclipse had a dead battery and now radio is saying
You need to call Dealer or stop at one to get proper code for your radio.You can check owners manual for reprogramming instructions.If not there I would suggest googling it.
Oct 03, 2009 | 2000 Mitsubishi Eclipse
I NEED A CODE FOR THE ECLIPSE CD3434
The radio will have to be removed from the car dashboard .
Removal instructions found here
www.fitaudio.com
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Sep 06, 2009 | Eclipse Car Audio & Video
1998 Mitsubishi Eclipse 2.0 non-turbo DOHC engine vin y. Car stalled and turns over but will not start. Towed to repair shop and at first they said it was a defective cam or crank sensor, but now they say...
don't get the "Cardone ECC model 793013" . i just check it out and when you click on the " See all vehicles this product fits " link, it shows this:
5fcbf9f.jpg ------------------------------------------------------------------
the problem with it is that the '97 PCM will not work on a '98. the pinouts on them are slightly different. The only 2 years that are interchangable are the 98 and 99 year models.
The part number for the correct one is 5293190AC.
If you get a remanned PCM that needs progamming, anyone or any shop with the correct programming tool can do it.
  • PCM (ECU) REPROGRAMMING
1995~1999 Mitsubishi Eclipse RS & GS with 2.0L non-turbo engine (Chrysler 420A engine) ECUs have been equipped with reprogrammable processors since 1995.
To reprogram Mitsubishi vehicles, you must use one of two different reprogramming tools. For the 1995~1999 Mitsubishi Eclipse RS & GS (with Chrysler 420A engine), you must use a Chrysler Flash Reprogramming Unit, MIT992000-A . Click here to order one from SPX, or call them at 1-800-533-5338.
I would suggest just buying a used (98 or 99)PCM. Then all you have to do is unplug the old one, take out 3 bolts to remove the bracket/PCM, pull it out, 3more bolts to remove the ecu from the bracket and bolt the new one in place. Its about a 5 min. job.
Nov 29, 2008 | Mitsubishi Eclipse Cars & Trucks
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
