The battery on the 2005 Quattroporte was disconnected. When reconnected the following problems occurred suddenly: AM plays but the station frequencies are not the correct frequencies No AM station list The FM station list and the preset listing on the right side of the monitor are garbled--it could be a letter, a frequency, a call sign, strange symbols or the first word of the song that was playing AF and REG always appear on the monitor even when deleted with settings Any thoughts?
3 Suggested Answers
SOURCE: deleted songs from sansa e260 still show up on the menu
Turn the player off.
Push the HOLD button to the locked position.
Press and hold the RECORD button while connecting to PC.
Let go of RECORD button when you see Welcome to Recovery Mode on the player's LCD.
You are now connected in, you guessed it, Recovery Mode. Open My Computer and you will find a new removable flash drive labeled, 16MB-FORMAT.
DO NOT ATTEMPT TO FORMAT THE 16MB-FORMAT VOLUME!!!
Open the 16MB-FORMAT volume in My Computer and create a new folder on the drive in its root directory. Name the folder sansa.fmt, use the Safely Remove Hardware icon in the system tray, and disconnect the player from the PC. The player should now format itself. If all goes well the format will be successful. If not, I suspect you might have a defective internal memory module. If it is defective, you can replace it with one from another v1 or Rhapsody model unit. You can often find defective players on eBay for parts. The memory module from the e250, e260, e270, or e280 will work just so long as its from a v1 or R model.
Posted on Aug 29, 2009
SOURCE: How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
Posted on Feb 04, 2011
System not programed
At R/H side of boot/trunk disconnect car battery neg terminal. Leave for up to 5 mins and reconnect. Its just like re-booting a computer, and will clear this 'fault'. Make sure you have Radio's 4 digit code and re-enter. If the fault was the result of a flat battery always re-charge battery with cars neg terminal disconnected, never re-charge with battery connected to cars elect system.
Mar 05, 2013 | 2007 Maserati Quattroporte Executive GT...
How to program 2007 maserati quattroporte after dead battery
how to progran the computer on the 2005 maserati quattroporte.
Oct 18, 2012 | 2007 Maserati Quattroporte Executive GT...
The check engine light comes on and it dies on occasion. It is intermittent. Had it scanned and was told the only fault was mass air flow sensor. Cleaned the mass air flow sensor, replaced fuel filter and...
Anytime you make a change to any part of the emissions system, its best to disconnect the
battery for a few minutes. If you don't, the computer retains the fault code and it will usually keep
coming back. When all power is lost to the computer, it will do a complete scan when reconnected
and engine started. Try disconnecting the battery for a few minutes then reconnect and see what happens.
Mar 05, 2011 | 1992 Buick Century
Cd in car stereo won't eject. I have a 2005 Chrysler T&C van and there is a CD in my stero that won't eject. Any suggestions?
Try turning the radio off and disconnecting the battery for 2 min then reconnect the battery and turn on the radio. This may reset the radio to default so you can eject the CD and reset your station preset and clock. make sure the radio is off before disconnecting the battery or your going to be prompt to program a radio code. Good luck and this should work.
Jan 02, 2010 | 2005 Chrysler Town & Country
I cannot get the CD player to eject the CD. the radio is a standard AM/FM radio with a CD player in a 2005 Ford explorer XLT. after pushing the eject button the radio screen blinks ''EJ err''. The cd...
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
Sep 30, 2009 | 2005 Ford Explorer
My cd disc player won't eject the discs.. I have a 2005 chevy malilbu
Try this, turn the radio off and disconnect the battery for 1 min, after the battery has been reconnected, turn the radio back on and eject the CD and reset the station and clock. Make sure the radio is off when battery has been disconnected or your going to be prompted to enter a radio code to activate the radio. Good luck and keep me posted.
Jun 26, 2009 | 2005 Chevrolet Malibu
2005 chevy colorado cd problem
Try resetting the radio, turn the radio off and disconnect the battery for 30 seconds. Make sure the RADIO IS OFF OR YOUR GOING TO BE ASKED TO ENTER THE RADIO CODE TO HAVE THE RADIO ACTIVE AGAIN. After the battery has be reconnected, turn on the radio and reset your clock and stations. Your CD plays should be working again too. Good luck and hope this helps.
Jun 15, 2009 | 2005 Chevrolet Colorado
HOW TO RESET SERVICE MAINTENANCE LIGHT ON 2005 MASERATI QUATTROPORTE
The usual way to reset them is to disconnect the battery cable for about 2 minutes.
Apr 17, 2009 | 2005 Maserati Quattroporte
Jump start
its in the trunk on the right side this is a door open it
Apr 11, 2009 | 2005 Maserati Quattroporte
2001 Mitsubishi Monteo Sport radio/CD lost functions?
I have seen this before, You should pull the radio out and get the serial number off of the back. Call your dealer and get the radio code. Disconnect and reconnect your battery and input code given by dealer. Usually this occurs when you change or let the battery rundown, it is an antitheft feature. Most of the time you would lose all functionality but in your case there may have been some kind a electrical surge that tripped part off your radio functionality. Please let me know if this works for you.
Feb 27, 2009 | 2001 Mitsubishi Montero Sport 4WD
18 people viewed this question
 Grubhead
Grubhead
