Question about Carrier TSTATHCP Programmable Thermostat Air Conditioner
The carrier infinity thermostat is blank
How do I start it to work
3 Suggested Answers
kstfas
  • 75 Answers
SOURCE: Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Posted on Aug 27, 2007
  • 38 Answers
SOURCE: Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Posted on May 07, 2009
Carrier infinity thermostat went blank when I touched my finger on the fan button and a static charge jumped from my finger and the screen went blank. All functions are working except the screen.
Every issue I've had with the Infinity has been a strange one. The blank screen is something I've seen and it was just a month ago. But I have no idea how I fixed it. Screen was blank but had the back light illuminated/was green but no numbers or letters displayed. I removed the tstat from its base, checked the pins on the back to see if any were bent or damaged. Tightened all wire terminals. Checked for 24v(present). Reinstalled to its base. Walked to my work truck and downloaded a manual. Walked back inside and the screen was now visable, with all numbers/letters present. I'm guessing I reset it by removing it from its power source? Also, at the indoor units' control wire terminal block, there is an A B C D. And most installers will connect 2 wires in each of these terminals. This is not correct and will give trouble due to a lost connection. You can try to tighten these low voltage terminals A B C D. The correct way to wire is at A, 1 wire is connected. That 1 wire is then connected to the 2 wires with a wirenut. B C D should be in the same way. 2 wires in this 1 terminal WILL lose connection and not communicate with the tstat. If this don't help, the tstat may need to be replaced. Hope this helps!
Mar 13, 2017 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Infinity system. Why is the wall thermostat display blank?
Either an open control fuse at the circuit board, a fault at the circuit board, wiring to the tstat or fault at tstat.
Jul 09, 2015 | Carrier Heating & Cooling
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Feb 27, 2009 | Carrier Heating & Cooling
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
