Question about Polaris 380 In Ground Pool Cleaner
How to fix sideways Polaris pool sweep?
It moves, but always goes on it's side.
    Top Expert:
  • Polaris Master
  • 8,175 Answers
Check ballast ball on top if water inside replace
Posted on Apr 23, 2016
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
  • 10 Answers
SOURCE: Polaris moves in circles
Check the football looking ballast float on the back of the cleaner. You want make sure it has no water inside of it. You can pull it off and shake it next to your ear. Link to Head Float.
Posted on Nov 03, 2009
jharwell668
  • 640 Answers
SOURCE: polaris 380 sweep hose isn't
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Posted on Mar 17, 2011
jharwell668
  • 640 Answers
SOURCE: My polaris 3900 moves across
Check your wheel RPM. If the pool cleaners RPM is over 32, reduce the water flow so that the cleaner makes proper contact with the pool's surface. Verify the back-up valve is cycling. Lift the valve out of
the water and watch the jet. It should come on and go off. You might also need to adjust your thrust jet if it is causing the cleaner to lean too far to one side.
jharwell668
  • 640 Answers
SOURCE: Pool sweep wheels are not turning...
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
Posted on Mar 30, 2011
How to fix a polaris pool sweep tail from coming off
there should be a clip that holds it on probably in bottom of pool or in the bag
Aug 16, 2014 | Polaris VacSweep 280 Pool Cleaner with...
My pool sweep platinum legend will not move
if pressure from wall take off top see if wheels touching gears if not move out you can swap front to back also check hoses inside
Apr 07, 2012 | Polaris 380: Polaris Booster Pump
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
Pb4 pushes air with litle water
the line in front of the pump which is your suction side is sucking air this line need to be replaced you can just cut the pipe off un tread the male connector and put more teflon tape on it but it will be only a temporary fix is always better to replace the male tread connector
Jun 14, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris 380 In Ground Pool Cleaner Logo
111 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
