Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
Why doies my Polaris pool sweep goes sideways?
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
john224
  • 1378 Answers
SOURCE: Installed a new 3/4 hp Polaris pool sweep pump.
Those pumps are dual voltage...Are you certain you connected it correctly for the voltage present? If the motor is set up for 230V (as it usually is when purchased new) and you only feed it 115 volts it will heat up and then act as you are describing. The side of the motor will have a diagram for how to reconnect the motor if necessary.
If connected correctly you would have a voltage issue in the line to the pump (unlikely). Check the voltage present at the motor terminals under load and look for a drop of more than 10%. If this is the case you will likely need an electrician.
Like I said though, it is usually because of wrong voltage setup for the problem you describe.
Posted on Dec 19, 2009
  • 333 Answers
SOURCE: If i have a polaris pool sweep system can i still
yes
Posted on Jun 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: I need to know how to put on new belts on a
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
jharwell668
  • 640 Answers
SOURCE: polaris 380 sweep hose isn't
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Posted on Mar 17, 2011
Water comes out of the tail of polaris 360, but tail does not sweep.
check the filter in the wall of the pool where the Polaris line hooks up, it got a small filter in it. you are running it on low-pressure that's why it not sweeping, could also be a plugged impeller on the booster pump.
Jay the pool pump motor repair guy Longwood Florida
Jun 21, 2017 | Polaris Pool & Spa
How to fix sideways Polaris pool sweep?
check ballast ball on top if water inside replace
May 13, 2014 | Polaris 380 In Ground Pool Cleaner
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
My Polaris 3900 sweep hose simply drags behind the vacuum. I've adjusted the sweep jet, but it doesn't appear to do anything. I'm also finding that the vacuum is gettin hung up when it gets to a the...
The hose connected on the interior of the polaris could be disconnected. seperate the housing and you will see the hose. Or you need more pressure at the wall. Try closing are reducing the amount of flow to the skimmers to up the flow at the wall connection. Your back up valve should pull the polaris off the steps. Set the rotating jet propulsion on rear to 11: 00 position.
The Pool Tech
Jun 13, 2010 | Polaris 3900 Sport Automatic Pool Cleaner ...
Pool sweep wheels are not turning
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
70 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
