Question about HP LaserJet CP3505n Printer
P3015 firmware how to download
P3015 hp lasser printer 49.4C01 error proper solution
Sounds like a bad formatter. I would try a firmware upgrade first and if unsuccessful, would replace the formatter. These formatters are infamous for failure.
Feb 22, 2015 | HP RB1-3015 LaserJet 4L Laser Scanner...
How do I fix the "phantom" paper jam on HP P3015?
Just had one today that would throw a open rear door error. Turned out that the flag in the back of the fuser was dislodged.
Sep 29, 2014 | HP Office Equipment & Supplies
59.30 error intermediatly in HP P3015
fuser motor startup error, possibly fuser is bad
Jan 09, 2014 | HP P3015 Laser Printer
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
Hp laser jet p3015 not powering on
41.2 error hp laser p3015 printer
Mar 25, 2013 | HP Laserjet P3015X Printer
Replacing Laserjet4 with P3015 no printout
Make sure that the IP address is the same as the LJ4
When you display the printer from the control panel can you actually see it?
Look at the properties and check the IP address
Oct 26, 2011 | HP P3015 Laser Printer
P3015 with a persistent 49.4c03 error on startup. I am an HP tech but this has me stumped. Customer was getting intermittent 49.4c03 error so he attempted a firmware upgrade via USB connection. ...
After unpluging the usb cable the printer would ready but go right back to the error after pluging it back in. We shut down the computer and printer for 30 minutes, when we turned them back on it printed what was in the que but went right back to the error code. Finally, I turned off the printer deleted the P3005 driver from the computer and rebooted, then turned the printer back on. The computer seen the new hardware and reloaded the driver by itself and now is fine.
Mar 24, 2011 | HP P3015 Laser Printer
HP Laserjet P3015 Error 49.ff04
These errors are almost always caused by outdated firmware. Print a configuration page and check the firmware version against this website . If your version is older than the one on HP's site then download the top option which is the easy install version and run it on your computer.
Mar 11, 2011 | Office Equipment & Supplies
HP LaserJet CP3505n Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
