Question about Exercise & Fitness
Platinum go fit treadmill error 1 appears what is this?
Works initially for about 8 mins then stops and won't restart ... error 1 appears on screen
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
SOURCE: V-fit treadmill belt wont turn
call the threadmill cops. they will come and beat up that error
Posted on Nov 05, 2009
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
Error code cof32 & c0070 at bizhub 210 how con i fix it?
Solution for Error code C0F32
1-Turn the machine ON. 2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
Error Code C0070
Solution:
1- Open the front door and bring the bottle out.Now restart the machine.if the code appears then open the toner hopper section.Toner hopper drive motor is not working, Dis mental the hopper section.
Jan 27, 2014 | Toshiba E-Studio167 Copier
I have canon pixma 310 its say chech ink u163 what thats mean
Good Day Sandip920!
Error U163 means, the printer detected that your black ink cartridge has been refilled with new ink.
It is very easy to clear this error and keep your printer printing.
How?
1. Turn on your printer.
2. When error U163 appears, press and hold the STOP/RESET buton on the printer. Hold it down until the printer self restart and initialize.
3. if after U163 is cleared off and appear another error, U162, press and hold again the STOP/RESET button and wait till printer self restart and initialize again.
Hope this helps!
Don't forget to rate my answer.
Thanks for asking Fixya.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Error 5200 canon mx 328...
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Mar 18, 2011 | Canon MX300 Office All-In-One Printer
My canon mx320 multi function printer doesnt want to scan. it shows a U051 code and refuses to work.does a printer need tp have ink to scan?? i dont think so. pl help
Need to reset the cartridge.
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U041, U042, U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
For error U162 or U163 All functions of the all-in-one printer will stop and your printer will not work.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Please give this solution a good ratings. thanks
Dec 06, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
I have an error 5200 The green light flashes and the orange alarm flashes.does not print. have tried unplugging the printer. then plugging it back in. Does not work.
This will work
Sep 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Error 5200
Needs reset
Aug 23, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Error code 501 solution
To clear error 5100 clean the surface of the copper contact of the ink cartridges with a moistened cloth and let it air dry. Fix the cartridges to the holder and return properly the cover of the printer.
These 2 reset procedures will help you clear the errors displaying in the control panel of the printer and let you print again.
To clear U053, U051 and U052
To clear error U162 or U163
Aug 10, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Canon mx310 error message U051 check ink
This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
Let me know if this works with you
Please rate this solution. Thanks
Aug 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Mx328 disable check ink how to do this or disable ink low
To disable ink low detection, do this steps:
To disable detection of reused cartridge, do this step:
Please find the complete explanation in my tips in this link
http://www.fixya.com/support/r5191523-canon_pixma_mx320_disable_ink_cartridge
May 20, 2010 | Office Equipment & Supplies
Panasonic UF-490 Fax "Power Failure 887"
try the all job clear.. press the ff.
FUNCTION 7 Monitor(4 times) then *(asteris or star)
Service mode is appear.. scroll arrow down.. select Ram initialize by pressing set.. then scroll down look for All Job Clear then set..
Aug 31, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
Exercise & Fitness Logo
69 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
