Question about Motorola CP200 Two Way Radio
How to boost the signal Motorolla CP200XLS - Motorola CP200 Two Way Radio
  • Motorola Master
  • 1,654 Answers
First, check your programming to see you are operating at full power (4W UHF or 5W VHF). Secondly, use the standard 6" antenna which came with the radio. (Stubby antennas will reduce range). Third, educate users to hold the radio with the antenna perpendicular to the ground. Tilting the radio to the side will reduce range. Fourth, have your radio, if older, retuned and aligned to bring it back to factory spec. Lastly, if range is still a problem, you might check to see if there is a system or repeater you can utilize in your area to extend the range of your radios.
Best regards.
Posted on Dec 24, 2014
Code p0234
P0234 Description
The boost pressure sensor responds to pressure changes in the intake manifold. This pressure is created by the turbocharger and changes with accelerator pedal position (APP) and engine speed. The engine control module (ECM) uses this information to assist in diagnosis of the barometric pressure (BARO) sensor and to provide engine overboost protection. The boost pressure sensor has a 5-volt reference circuit, a low reference circuit, and a signal circuit. The engine control module (ECM) supplies 5 volts to the boost pressure sensor on the 5-volt reference 2 circuit, and provides a ground on a low reference circuit. The boost pressure sensor provides a signal to the ECM on a signal circuit relative to the pressure changes. The ECM monitors the boost pressure sensor signal for voltage outside of the normal range. The ECM calculates a predicted value for the boost pressure sensor. The ECM then compares the predicted value to the actual signal.
Read more: http://engine-codes.com/p0234.html#ixzz2e2DssWbP
Sep 05, 2013 | Volvo V40 Cars & Trucks
Motorola Radius CP200 flashing yellow when charged
The battery is no longer taking a charge properly and needs to be replaced.
Feb 12, 2013 | Motorola Mint Radius Cp200 Uhf 4ch Radio
I have a motorolla at&t razr. i insert the boost sim card n it reads boost signal but my phone is blocked cuz i have to enter a susidy password... i dont know whats the subsidy password. how can i get...
You are trying to use your AT&T phone on the Boost Network. Motorola has put a code to prevent you from using their investment (your phone) on another network. The term "subsidy" refers to the discount they gave you when you purchased the phone from them at a discount, or "subsidy". You can try to search CraigsList for a local person who has software to unlock your phone. Search CraigsList for "unlock motorola cell phone". They will charge you a fee of around $25 to $50.
Mar 16, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorolla phone tools wont detec my phone i have a boost i465
BOOST MOBILE HAS RINGTONES DISABLED... YOU WONT EVEN BE ABLE TO DOWNLOAD THEM FROM MYXER.. BUT YOU CAN BUY THEM OFF OF THIER WEB SITE...... THANKS AND I KNOW HOW YOU FEEL.. THATS WHY I SWITCHED BACK TO CRICKET..........
Sep 01, 2009 | Motorola Mobility Mobile PhoneTools 3.0...
P236 troub le code 2002 cummins in a dodge 1 ton
Computers and Control Systems: Diagnostic Trouble Code Tests and Associated Procedures
P0236
SYMPTOM
P0236-MAP SENSOR TOO HIGH TOO LONG
WHEN MONITORED
Engine running.
SET CONDITION
Boost pressure signal indicates boost pressure is high when other engine parameters (i.e. speed and load) indicate boost pressure should be low or
boost pressure is low when other engine parameters indicate it should be high.
POSSIBLE CAUSES
- Other codes
- Checking boost pressure sensor
- Checking the 5-volt supply circuit
- Sensor ground circuit open
- MAP sensor
- MAP signal circuit open
- MAP signal circuit STV
- MAP signal circuit STSG
- MAP signal circuit STG
- ECM
Sep 01, 2009 | 2002 Dodge Ram Maxi
Froze display
yes sir for some reason myphone does the same stuff but it not also charging my battery can you help me solve this i already treid another battery does the same thing.
Jun 04, 2008 | Motorola Mobility C290 Cellular Phone
My Motorolla W375 - No Service
I 've got motorola W375 for present over from AU and when I inserted my sim card in, first ? is insert subsidy password which i don't have ( vodofone office too) how can i find and use my new mob. ph.?TA
Feb 19, 2008 | Motorola Mobility W375 Cellular Phone
Motorola CP200  Two Way Radio Logo
108 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
