Question about Grilling
How do you install the wheels on a charcoal grill 625
3 Suggested Answers
SOURCE: JVM1750SMSS CHARCOAL FILTER INSTALL
I just installed a JVM 1540 with the same grille. I removed the two top phillips screws before mounting the oven as I cannot access these screw heads once the oven is installed. It took me about 20 minutes of fiddling with the grille to figure out (no thanks to the manual) that the grille needs to slide to the left to release so you can change the light bulb/charcoal filter.
Posted on Oct 28, 2008
  • 8 Answers
SOURCE: charcoal grill to propane
Shouldnt be a problem, the sell replacement kits for propane grills at most home improvement stores. Just buy the replacement kit and install it into your grill.
Posted on Feb 16, 2009
Do I need briquettes for my weber silver grill
No, you don't use briquettes with a charcoal grill. Charcoal is slow to heat up any way, adding lava rock (briquettes) would make it even slower and hard to keep lit. However, its OK to add cooking wood chunks after the charcoal has heated up, to add a smokey flavor.
Happy Grilling!!
May 24, 2011 | Weber One Touch Silver Charcoal Grill
I can't get the temperature high enough to go beyon warm, no matter how many briquets I place in the bottom pan.
Most of the time, it's not how much charcoal you use, it's how and where you place the charcoal pan for grilling and searing, as opposed to smoking food. The higher the charcoal pan in the grill, the more air it gets and the charcoal gets hotter. To illustrate this I have included a link to your Owners Manual (in case you have misplaced yours), to you can download and print for future reference. Pay particular attention to page # 9 - Grilling and Searing.
http://images.brinkmann.net/docs/pdf/810-5301-C.pdf
I would add to what your Owners Manual says about what type of charcoal to use, by suggesting that you use all natuarl lump charcoal, instead of briquette type charcoal. It the all natural lump charcoal is easier to light, without starter fluid. Plus, it burns cleaner and hotter than briquette type charcoal.
This should help you solve the issue you're having Happy Grilling!!
Apr 26, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
I just bought a 18.5 in. weber and after im done cooking and close the vents the coals continue to burn much longer then my 2 previous grills.
Sue, this question/problem has been voiced a couple of times before and I'm not sure it's a problem with the grill. It's more of a problem, of how much charcoal is being used and how long it takes to grill whatever you're grilling, how many portions are being grilled and how long it takes.
My experience has been, after during numerous grilling demonstrations and cooking shows, most folks use way to much charcoal for what they're trying to grill. Charcoal is slow to heat up completely and slow to cool off and extinguish. Especially, if you're using to much charcoal. The slogan I always use when cooking with charcoal is "less is more". When you use less, throw in a couple of chunks of Western Cooking Wood. It will add a great flavor and may convince you to switch to it entirely. Also, all natural lump charcoal lights faster and burns cleaner than charcoal briquettes. It also cools off faster, when the grill is closed completely.
Give it a try, I know you'll see a difference.
Apr 13, 2011 | Weber Grilling
Use of Charcoal or Lava Rocks in the Char Broil Patio Caddie?
LP grills are designed to use lava rock ONLY. Charcoal will clog the burners.
May 16, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Charcoal in a gas grill...Wassup with that?
Well are they lava rocks or charcoal? The Master Flame series is supposed to have lava rocks. If what you see is charcoal, remove it and replace with the lava rocks. You can order the rocks from Char-Broil's website.
Sep 06, 2009 | Char-Broil CharBroil Master Flame Gas...
Message to change filter but unit exhaust up to stack?
Grease filters change from the bottom side of the unit.
Charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE XL1800 1100 Watts Microwave Oven
Changing filter
The grease filter is changed from the bottom of the unit.
The charcoal filter is changed as follows:
pull the plug.
oven and remove it.
and screws.
Aug 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Charcoal grill to propane
Jan 29, 2009 | Sport & Outdoor - Others
Nov 06, 2007 | GE JVM1750SMSS Microwave Oven
Grilling Logo
46 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
