You should be able to find what you need at the following site:
http://www.hhdonline.com/
Hope this helps
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Hi. I have a Hamilton Beach Model 2202 and it's been working fine until last week. Now I have no cold water.
