Question about Honda Electrical Supplies
Honda generator ex7 not working - Honda Electrical Supplies
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
Hi I have a 92 Honda accord my safety indicator unit lights came on the door the trunk and the brake lights are on everythings working what could it be
Now you can unlock any honda radio whit the honda radio code generator from this page : http://www.unlockphonetool.com/honda-radio-code-generator-for-free/
Honda Radio Code Generator For Free
Oct 01, 2015 | Honda Cars & Trucks
Honda gx400 parts
Honda GX400 either a motor car (which will have a '12V Generator' on board..) or a largish sized Honda utility engine for water pumps, fans and electricity generation of of over 5KW (5KVA)
Sep 09, 2014 | Honda Electrical Supplies
WHERE CAN i GET THE SPRING FOR THE PULL START ON ETQ 3000 GENERATOR
Never heard of an etq Honda generator,if is a Honda generator any Honda dealer should be able to help you. If its a Honda knock off ,some Honda springs will work.
May 30, 2014 | Honda 3000 Watt Portable Generator
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Want to reset sony vpl ex7
where it the RESET located? I do not have any on my VPL-EX7
Jan 02, 2012 | Sony VPL EX7 LCD projector 2000 ANSI...
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Honda 7000w generator outputs 6vAc when idling. When I rev it, power is then supplied. Why?
Well I dont know, but I do know that when it idles nothing is going to work. So whats the use of having a generator idle? Generators must turn at 1800 or 3600 rpm to operate.
Mar 13, 2010 | Honda Electrical Supplies
Electrical Supplies Logo
29 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
