YKEHSO2RWHO starts fine with auto or manual but stops within 4 minutes or shorter. Thermister is new, Thermal fuse O.K., Thermal cut-off ok, high-limit thermostat o.k, passes all the diagnostic tests.
Run only air dry mode, dryer behaves the same. Starts then stop within 2 minutes.
Is this the control board?
The moisture sensor is just fine. It passed the moisture sensor factory test.
I have a kitchenAid dryer model YKEHS02RMT1 just
about 2 years. (it was brand new when I bought it.)
I tested this thermal fuse and it is still
O.K.
I just replace the thermister even though the old
one is still O.K.
I ran the diagnostic tests that came with the
trouble shoot sheet, all the tests are passed.
The problem that I am having is that the dryer
would stop voluntary in around 2 or 4 minutes in either auto or manual
mode.
When it stops, the symptons are :
1) The front door open
2) the remain timer indicator flashing
3) no sound
I also noticed that, the front door would
automatically opens when the dryer is in idle when the inside the dryer is still
hot.
Would you have any idea why the door automatical
open by itself? Does the controller control the opening of the
door?
Thank you in advance,
Hong
